M111 (2.3L) Supercharger Intake Resonator (baffled muffler) removal
#101
My car has an eppeleptic fit after I removed the MAF screens but was fine after a while.
Yeah, do the "Learning in the recirculation flap".
https://mbworld.org/forums/c-class-w...re-m111-2.html
#102
2002 C230 Coupe
Where exactly is the flap? the box over the supercharger manifold that had to be removed you mean?
#103
No remove the air filter box.
It'll be on the left when standing in front of the car. Rubber hose from
airbox to it.
airbox to it.
#107
2002 C230 Coupe
I noticed today that one of the sc manifold bolts is missing, I'm assuming I'm probably losing air. I guess I'll find out once I get another bolt.
Where is a good place to order the bolt and a new hose that goes into the valve cover
#108
I doubt one bolt would make it lose air if the other 5 are tightened well. It should he the wastegate solenoid because I realized everytime you disconnect the wire you have to reset it. Also if your PVC pipe is not on try not to drive your car too much because it will leak oil into your entire intake system. Which looks like already happened since you had oil in the MAF
#109
2002 C230 Coupe
I found the problem. A hose behind the airbox was left disconnected, once I put that back onI am getting full rev again. I put tape on the pcv hose just to test the car but I'll replace the hose before I drive it any more. I guess I still need to resrt the wastegate too.
#110
I can't believe you actually suspended him. What is this, high school? "BAD BENZ OWNER! BAD!" Petty moderators and their magic wands, I swear...
The original poster is a good friend of mine going back many years. I've seen this car go from the somewhat undewhelming stock appearance and setup when he first bought it (still a great deal at used prices, don't get me wrong), to the very cool ride he has made it today. It looks fantastic, it sounds good, and it packs a decent punch for what it is. Definitely a head-turner.
I've been on the Benz forums for about a year, and this place sorely needs people who actually know what they're talking about. To run him off just because he violated the Sacred Trust of a PM (oh no!) or made the grave error of (gasp!) mentioning his place of work is retarded with a capital Type-R.
Keep your fingers crossed that he bothers to return after the Principal's Office lets him back, he's one of those guys everybody with a C-class will be referring to when they start kicking around ideas for their own mods.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Just thought I would bump this to the top for a second to remind everyone why these forums suck so bad. A bunch of moderators and people with questions but no answers don't make a good resource. And everyone with knowledge gets chased out of here.
I have been STFF for information on the silencer removal for hours, finally thought I had found a thread where someone was going to provide useful information and BOOM the mods ban him. This is why people who know what they are doing leave this place in droves.
I had a similar run in with the mods a couple years back where some guy who had no idea what he was talking about told some poor kid his engine was going to blow up. Since I had over 2 years of experience working on cars as a job at that point I corrected the guy and informed the OP that his car was fine. The poster then informed me that because I only had a couple of posts and he had a couple hundred (most of which, btw, were things like "good job" and "STFF newb") I was automatically wrong even though he admitted he had never actually worked on the parts he was talking about. And I got an PM from the mods informing me that if I disagreed with him again I would get a ban.
What a wonderful resource this place is. Btw, your format ***** *****. You can't find ****, you don't consolidate any useful information in a usable way and searching the forums for something results in 100 hits of people saying STFF and 1 dead link to the only time anyone answered the question. Just thought I'd bump this to the front so a couple people could see it before I get my ban and this gets removed.
#111
Super Moderator Alumni
Audi A5 Sportback + Cannondale Prophet
Seriously? You're complaining about a ban from 8 years ago? That's a pretty persistent grudge. I can't even figure out who it is that got banned.
#112
2002 mercedes c230 Kompressor
2002 Mercedes C230 Kompressor
Any one ever tried bypassing the supercharger air bypass vaulve? I did it and i recieved quite a bit more boost. somewhere around 10-12psi. Whats the deal with the air intake resinator.
#113
I don't have any pictures bit I can take some here soon.. But I took the vacuum line from the supercharger and instead of it running through the electronic vaulve and bypass valve, I ran it straight to the intake, and just plugged all other hoses
#115
02 mercedes c230 kompressor
Any one ever looked up on the electromagnetic clutch to the supercharger? If you could supply power and ground without the sensing circuit.. Could you be at fill boost at all times?
#117
Electromagnetic clutch
Actually there is.. And from my understanding it acts as a ac compressor witch allows your rotors to free spin at certain times.. Also has anyone done an upgraded Intercooler? I am picking up one friday and was curious if anyone has had any gains
#119
It's an Eaton M45. There is NO clutch. It spins all the time.
Don't believe me, go take the supercharger out of your car and have a look. I have.
#120
You are correct my bad..'I read wrong on All-Data.. But if you have had it apart then you know where the intake resonator is?
#121
As for the upgraded intercooler, I never bothered since heat didn't seem to be an big issue, even on hot summer days in florida. A big intercooler on a supercharged car isn't a great idea unless you're running a lot of boost.
The intake resonator is just for sound, won't increase any hp. It's located under the supercharger manifold. You have to remove the black oil catch can system, the recirculation flap, the manifold and then remove it from the manifold and re-install everything.
Xsawgx (04-12-2016)
