0W-40 only?
Old Aug 28, 2007 | 11:46 AM
sanf's Avatar
E53
0W-40 only?
for the ppl who changes their oil every 5k. do you still use 0W-40 ? the dealer runs 0W-40 for up to 12k miles (service A/B). what's the deal ?
Old Aug 28, 2007 | 12:20 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Check your owners manual packet. A list of approved lubricants should be enclosed. And yes, other weights can be used. I'm currently running
10-30 because it was on sale. 0w is only needed for extreme cold.
Just bought a case of 5-30 as that was also on sale. But neither was specifically mentioned in the manual, so I be taking my chances a little, but heck they're the latest tech synths so likely they just haven't gotten around to testing them (non-mobil1 which is crap anyway). And i plan to change more frequently since it was $1 a quart after rebate. Check you local kragens if you want to go that route, but check your manual first, and search the forum for lots of discussion on that already.
Old Aug 28, 2007 | 12:46 PM
uberwgn's Avatar
e300d
San, when you run an oil that meets 229.51 (latest spec), you can defer to the FSS for the correct oil drain interval. Run non-compliant oils and it's only guesswork as to when it needs to be changed.
The new dealer-only oil is now Mobil1 ESP 5W40 meeting 229.51 spec. The Mobil1 0W40 is still fine assuming you don't have a brand-new car. I see this oil at Wall'sMart, Autozone, etc.
Old Aug 28, 2007 | 01:29 PM
sanf's Avatar
E53
sounds good. thx ~~
Old Aug 28, 2007 | 01:33 PM
rlee02135's Avatar
2004 C32 ///AMG
I use 0W40.
Old Aug 28, 2007 | 02:39 PM
uberwgn's Avatar
e300d
there's an extensive list of oils (available in NAmerica) posted at Wolfgang's site if you run short of ideas on which product is good and which isn't
Old Aug 28, 2007 | 08:01 PM
RENNTECH's Avatar
G63
0w-40 Mobil 1 Always! Straight From My Factory Rep Thats All We Use In 1996 And Up When They Switched To Synthetic Interval Would Then Be One Year Or 13,000 Miles (10,000 On Amg)
Old Aug 28, 2007 | 09:33 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
modern day oil can stand up to longer period without the need to be changed, but I still do it every 5k miles anyway. I use either Mobil1 0w40 or LiquiMoly 0w40.
Old Sep 12, 2007 | 09:32 PM
LuxuryC240's Avatar
2003 C240
Is there a special kind of Mobil1 0w40 called European or something?? I need to get my oil changed tomorrow, and I'm gonna have to buy my own oil, and also is walmart the cheapest place to get this...as long as there is no need for special european sumtin, lol.... Something I came across while STFF!
Old Sep 12, 2007 | 09:38 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
M1
[<<0w-40 Mobil 1 Always! Straight From My Factory Rep Thats All We Use In 1996 And Up When They Switched To Synthetic Interval Would Then Be One Year Or 13,000 Miles (10,000 On Amg)>>
M1 0W40 has been factory fill since 2001 until MB changed to M1 5W40 (fleece filter) when FSS went away.
Old Sep 12, 2007 | 09:52 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
i would suggest using synethetic if you had to choose you can buy oil from the dealer or just hit up a autoparts store.... i rather use the synthetic mobil oil just b/c MB recommends it
Old Sep 12, 2007 | 09:58 PM
LuxuryC240's Avatar
2003 C240
Yeah I was going to use the mobil1 0w40 anyways...I had just seen in an older thread someone mention mobil1 0w40 european spec or something like that...if there is a such a thing I wouldn't want to get some other type of spec, which is why I asked.....thanks!!
Old Sep 12, 2007 | 09:59 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Mobil 1 0W-40 and 5W-40 ESP meet M-B’s 229.5 and 229.51 specifications for FSS, respectively. Ensure that your technician installs a Mann HU718/5x fleece filter (V6er’s) and you’ll be good to go on an extended interval until your next renewal.
Couple of links, if you’re inclined, so you don’t have to take my word for it-
http://www.mobil1.com/USA-english/mo...l_1_0w-40.aspx
http://www.whnet.com/4x4/oil.html
Old Sep 12, 2007 | 10:48 PM
LuxuryC240's Avatar
2003 C240
Thanks, thats some great info!
Old Sep 12, 2007 | 11:19 PM
w203elegance's Avatar
c240 elegance
My Mb dealer recommended QS 5w-50 pure syn.
Old Sep 12, 2007 | 11:35 PM
coin's Avatar
'06 CLK500
I think Advance Auto Parts have discount on engine oil prices this month.
Old Sep 13, 2007 | 12:06 AM
GraniteG's Avatar
a slow C
0w-40
I use 0w-40 and change the oil every 5000 miles. I think 5w-40 will be ok
Old Sep 13, 2007 | 12:53 AM
spyderpig's Avatar
'02 CL203 M111
yeah 0w40 to 10w30 is fine i guess according to the owner's manual...
I use 0w40... it is synthetic and goo performance...
Old Sep 13, 2007 | 01:14 AM
benzoc230k's Avatar
05 C230K SS
My Valves ping at cold startup for a few seconds. Is that normal for everyone else? I use MB1 0W40 with paper filter. Check this out, both dealerships here in oregon didn't know about the fleece filters that my MB is supposed to use. They did not carry them in stock even the parts dept. sell the paper filters for my 05. Is there something wrong with these MB dealers?
Sorry didn't mean to hijack this thread.
Old Sep 13, 2007 | 01:33 AM
RLE's Avatar
RLE
Pings and filters
<<My Valves ping at cold startup for a few seconds. Is that normal for everyone else? I use MB1 0W40 with paper filter. Check this out, both dealerships here in Oregon didn't know about the fleece filters that my MB is supposed to use. They did not carry them in stock even the parts dept. sell the paper filters for my 05. Is there something wrong with these MB dealers?
Sorry didn't mean to hijack this thread.>>
You didn't.
Valves don't ping. You had better head for the dealer for a diagnosis, particularly since your car is still under warranty.
As to the paper oil filters, they are fine if you aren't going 13K miles between changes. If you are, the fleece oil filter is required. And Mobil 1 5W40 EP.
My '01 C320 could go 10K miles between changes but I change it at 5K miles just because it makes me feel good. And I'm using up my stock of paper filters which I won't be using in my '08 C300 which is due in a few weeks.
I buy my oil and air filters, brake pads and so on from www.buymbparts.com in Atlanta much cheaper than the dealer for the very same items.
Old Sep 13, 2007 | 03:05 AM
Moviela's Avatar
Is everyone aware that the Mobil 1 0W-40 oil has a different additive package than other weight oils? The page in the manual that suggests that other weights may be used in different climates is mandated by government, and will appear in much the same format in other car manuals. You should be using sheet 229.5 oil in your gas engine, and while you can use 229.51 oils, they are aimed toward diesel engines. There is a reason Amsoil, Royal Purple, Swepco and other high priced oils are not used by Mercedes: They don't meet the specification of sheet 229.5. Some people might prefer these products, but I wonder if they also prefer a crankcase full of sludge?
You also need to use a fleece oil filter. Its made of polyester (same stuff as motion picture film) to last up to six times longer and work better than paper filters. Mann+Hummel has a piece that expains the benifits in a non-technical way: http://www.stankoff-bg.com/opencms/e...BAAEJwjOMP.pdf
I don't understand people who feel better changing the oil at 3000 to 5000 miles. When your gas tank is half used, do you dispose of the other half and fill up? Well, Laurel and Hardy might, but only if it was funny. Do you feel funny when you dump your half used oil?
Old Sep 13, 2007 | 03:58 AM
benzoc230k's Avatar
05 C230K SS
You didn't.
Sorry I meant knocking not pinging. I checked out the fleece filters from some of the sites including the one mentioned below. All I can find is fleece filters for the 06's not the 05's. I have the long skinny filter now. Could I switch to the shorter fleece filter? Or can someone point me to the right direction.
Sorry
Old Sep 13, 2007 | 09:53 AM
slowrey's Avatar
2006 Mercedes C55 AMG
I change mine for peace of mind and because I drive hard. Gas verses oil are totally different.
Old Sep 13, 2007 | 11:30 AM
LuxuryC240's Avatar
2003 C240
I called my dealer this morning, and I will be going to get my oil changed this afternoon....They said it wouldnt be more than $87...I'm going to tell them to use the fleece filter...if they don't have it, I'll just get one myself or something...
I figured if I was going to buy all the quarts myself that would be around 60 plus 30 or so if I was going to have a regular shop do it, so it makes sense to just have the dealership do it...I was expecting around $90 anyways...
Old Sep 13, 2007 | 02:42 PM
polarbexar's Avatar
Veteran: Air Force
2025 Mazda CX70 Turbo S, 2015 G550
I think Moviela knows the diffence.
You may acutually do more wear on the engine by changing it more often. On diesel forums there would be great oil debates similar to this. Folks would send off oil samples for analysis. The result- Synth. oil can easily exceed 20,000 miles. And this is on an engine with a 19-1 compression and 35lbs. of boost. ( VW TDI ) Peace of mind is one thing, but wasting is wasting... I change at the recomended interval, but I also drive 100 miles a day. So take it for what you will, just enjoy the experience.
