Supercharger in my c230k
Old Sep 22, 2007 | 02:12 AM
Jdaswat's Avatar
how can i tell if the sc in my car isnt working properly?
Old Sep 22, 2007 | 05:46 AM
magnus203's Avatar
CL203, W211
eh????
well youd have some severe loss in power and you wouldnt hear it whine, and most likely the engine management light would be lit up on the dash. heh.
but yah, that was a pretty bad question, we need symptoms
Old Sep 22, 2007 | 09:16 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Quite simply, you'll know if it isn't working.
Our 1.8L/ 2.3L engine that is not feed by some sort of induction system propelling a car that is 3400lb will be extremely sluggesh to say the least, and even more so than a normally aspirated engine of the same size due to the compression ratio differences. You will not be able to keep up with traffic if it is not working
Unless your belt broke or you took off the air filter and it inhaled a stone or bolt, the reliability of a SC is almost bullet-proof with a extrememly low incidence of failure. Turbo's on the other hand are not as rugged and the failure rate on them is much higher, this is due to the high temperatures, the extreme importance of oil and failure to observe the proper cool down procedures after running long and aggressively
Old Sep 22, 2007 | 02:07 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Boost gauge?
Old Sep 22, 2007 | 03:34 PM
Jdaswat's Avatar
i dont know i'm new to cars and it just seems that mine is making some type of clicking noise or something when it's in drive just sitting there and also when im accelerating. Maybe it's supposed to be there, but it doesnt sound like it should?
Old Sep 22, 2007 | 03:54 PM
You need to isolate where its coming from.
Got ears?
check the belts, and pullies.
Figure where it's coming from.
You're asking for help, but providing no info.
Normally people here would shred a newbie with a question as vague as yours.
Maybe people are in a good mood as it's Sat.
Old Sep 22, 2007 | 04:22 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Got ears?
Are you kidding me? I saw the post, and thought, screw this. Guy can't help us, I surely have no inclination to help him.
If C230 helps you out, you seriously owe him a 6-pack or something.
E
Old Sep 22, 2007 | 04:26 PM
Jdaswat's Avatar
seeing as im only 16 i can get him a 6 pack of coke
Old Sep 22, 2007 | 04:41 PM
SeaCoupe's Avatar
Okay, you are 16, I'll bite. I'm going to look at this as a teaching opportunity. Take a empty paper towel tube. have someone throttle the engine, and use that tube against your ear to hear for your sound. Once you figure out where it is coming form come back and tell us.
Next, tell us how many miles, what year is your car, any recent maintenance done?
E
Old Sep 22, 2007 | 05:18 PM
Jdaswat's Avatar
alright thank you very much.
The car is a 2002 C230 Kompressor Coupe with 61K miles on it
the check engine light turned on about 3-4 days ago but i believe it was serviced when my parents bought it for me back in july.
i know this picture sucks but it sounds like it's whatever the noise is, is coming from around this belt?
Old Sep 23, 2007 | 05:30 PM
SeaCoupe's Avatar
For the life of me, i can't make that out. The main crank?
So you have noise coming from the belts? Does the noise happen in all gears, or only on Wide Open Throttle?
First thing I would do is insure that your tensioner bearing is tight. It is a 15 mm socket, and has a plastic pulley around it.
Any chance for you to do what I asked, then you can really dial in.
E
Old Sep 23, 2007 | 07:37 PM
WestCoastBenz's Avatar
I think even if you gave me a million dollars i couldnt guess what that picture is of. but yeah it looks like itll be the main crank, good call.
Old Sep 24, 2007 | 12:20 PM
ushawk1's Avatar
I downgraded to a VW, it's still German though
Boost gauge?
I thought about putting one on just for the fun of something to watch go back and forth, and because us pilot types can never have enough gauges. I just don't know where I would it in the cockpit. Maybe build a little mount in the space below the radio. I'll see if I can get an STC for it. You know those FAA inspectors these days....
Old Sep 25, 2007 | 10:28 AM
polarbexar's Avatar
Veteran: Air Force
2025 Mazda CX70 Turbo S, 2015 G550
Just stick a Garmin 1000 in there. You could monitor everything....
