VSS Speed Sensor connection
Heres a link scroll down to the bit about the speed sensor, the part number for the connector may not be correct for your car (UK im assuming? mbclub.co.uk
) so you may want to ask your dealer for that part.https://mbworld.org/forums/showpost....5&postcount=14
Why do I need a Speed sensor Connector housing was that just for you van unit ?
What year was your car ?
For a C class, I have now been told I can use a connection on the ESP, PIN 3 of the BIXENON levelling connector (maybe thats the same as your answer?), a blue wire from the passenger sill or Pin A1 from the headunit block connecter ?
Cheers
Adam
