Wheel bearing diagram
Did you mean the rear wheel bearing?
35 REAR AXLE
Chassis=203261 Group: 35 REAR AXLE
Subgroup: REAR AXLE SUSPENSION
Key Part No. Description
010 2033503508 001 REAR SUBFRAME LEFT
010 2033503408 001 REAR SUBFRAME RIGHT
020 A2013520027 2203520227 - JOINT
020 2203520227 001 JOINT LEFT
020 2203520227 001 JOINT RIGHT
030 2029810127 001 ANGULAR CONTACT BEARING LEFT
030 2029810127 001 ANGULAR CONTACT BEARING RIGHT
040 2019941641 001 LOCK LEFT
040 2019941641 001 LOCK RIGHT
050 2033570008 001 FLANGE LEFT
050 2033570008 001 FLANGE RIGHT
070 2023500206 001 SPRING CONTROL ARM LEFT
070 2023500206 001 SPRING CONTROL ARM RIGHT
080 2023520165 001 RUBBER MOUNTING LEFT
080 2023520165 001 RUBBER MOUNTING RIGHT
090 2109900504 001 SCREW SPRING CONTROL ARM TO WHEEL BEARING LEFT M14X1,5X90
090 2109900504 001 SCREW SPRING CONTROL ARM TO WHEEL BEARING RIGHT M14X1,5X90
100 910113014000 001 NUT SPRING CONTROL ARM TO WHEEL BEARING LEFT M14
100 910113014000 001 NUT SPRING CONTROL ARM TO WHEEL BEARING RIGHT M14
110 2033520088 002 COVERING SPRING CONTROL ARM
120 2109900336 004 SCREW COVER TO SPRING CONTROL ARM
130 308765012023 002 SCREW SPRING CONTROL ARM TO REAR SUBFRAME M12X1.5 X 90
140 2103570275 004 WASHER SPRING CONTROL ARM TO REAR SUBFRAME
150 0019903950 002 NUT SPRING CONTROL ARM TO REAR SUBFRAME M12 X 1.5
160 1403522271 002 SCREW TIE ROD TO REAR SUBFRAME M12X1.5 X 67
200 2103503406 001 CAMBER STRUT LEFT
200 2103503406 001 CAMBER STRUT RIGHT
210 0029902812 001 SCREW CAMBER STRUTS TO WHEEL CARRIER LEFT M12X1,5X80
210 0029902812 001 SCREW CAMBER STRUT TO WHEEL CARRIER RIGHT M12X1,5X80
220 2103570675 001 WASHER CAMBER STRUTS TO WHEEL CARRIER LEFT
220 2103570675 001 WASHER CAMBER STRUT TO WHEEL CARRIER RIGHT
230 0019903950 001 NUT CAMBER STRUTS TO WHEEL CARRIER LEFT M12 X 1.5
230 0019903950 001 NUT CAMBER STRUT TO WHEEL CARRIER RIGHT M12 X 1.5
240 0099902001 006 SCREW THRUST ARM, CAMBER STRUT AND STRUT ON REAR SUBFRAME M12X1.5 X 60
250 0019903950 006 NUT THRUST ARM, CAMBER STRUT AND STRUT ON REAR SUBFRAME M12 X 1.5
260 2103503306 001 STRUT LEFT
260 2103503306 001 STRUT RIGHT
270 0029902812 001 SCREW STRUT TO WHEEL BEARING LEFT M12X1,5X80
270 0029902812 001 SCREW STRUT TO WHEEL BEARING RIGHT M12X1,5X80
280 2103570675 001 WASHER STRUT TO WHEEL BEARING LEFT
280 2103570675 001 WASHER STRUT TO WHEEL BEARING RIGHT
290 0019903950 001 NUT STRUT TO WHEEL BEARING LEFT M12 X 1.5
290 0019903950 001 NUT STRUT TO WHEEL BEARING RIGHT M12 X 1.5
330 0029902812 001 SCREW THRUST ARM TO WHEEL BEARING LEFT M12X1,5X80
330 0029902812 001 SCREW THRUST ARM TO WHEEL BEARING RIGHT M12X1,5X80
340 2103570675 001 WASHER THRUST ARM TO WHEEL BEARING LEFT
340 2103570675 001 WASHER THRUST ARM TO WHEEL BEARING RIGHT
350 0019903950 001 NUT THRUST ARM TO WHEEL BEARING LEFT M12 X 1.5
350 0019903950 001 NUT THRUST ARM TO WHEEL BEARING RIGHT M12 X 1.5
360 2013520988 002 COVERING THRUST ARM
370 2103503806 001 THRUST ARM LEFT
370 2103503806 001 THRUST ARM RIGHT
400 2033500753 002 TIE ROD PARTS KIT
405 1403501170 002 REPAIR KIT TIE ROD TO REAR SUBFRAME
410 2013528865 002 RUBBER MOUNTING Optional with: A 1243524365
410 1243524365 002 RUBBER MOUNTING REPAIR SIZE; WITH ECCENTRIC INTERIOR BUSHING Optional with: A 2013528865
420 910113010001 001 NUT TIE ROD TO WHEEL BEARING LEFT M10 *027 *028
420 2029901151 001 NUT TIE ROD TO WHEEL BEARING LEFT M10 *029 *030
420 910113010001 001 NUT TIE ROD TO WHEEL BEARING RIGHT M10 *027 *028
420 2029901151 001 NUT TIE ROD TO WHEEL BEARING RIGHT M10 *029 *030
440 0019903950 002 NUT TIE ROD TO REAR SUBFRAME M12 X 1.5
450 2039800016 002 ANGULAR CONTACT BEARING REAR WHEEL BEARING
460 2023500106 002 REPAIR KIT FASTENING PARTS TO SPRING LINK
470 2103504506 002 REPAIR KIT MOUNTING PARTS CAMBER STRUT
470 2103504506 002 REPAIR KIT MOUNTING PARTS STRUT
470 2103504506 002 REPAIR KIT MOUNTING PARTS PUSHING STRUT
*027 UP TO DATE: 05.10.2001
*028 UP TO DATE: 26.11.2001
*029 FROM DATE: 05.10.2001
*030 FROM DATE: 26.11.2001
Please notice that Key number 450 is a kit that contains the bearing and consumables to finish the job.
35 REAR AXLE
In the interest of equal time and fair play, here is the front:
Keep in mind this is for S203 (wagon) 203.261, so verify part numbers against your chassis at your parts dealer.
33 FRONT AXLE
Chassis=203261 Group: 33 FRONT AXLE
030 Subgoup: STEERING KNUCKLE AND CONTROL ARM
Key Part Number Description
010 2093320001 001 STEERING KNUCKLE LEFT
010 2093320101 001 STEERING KNUCKLE RIGHT
030 2093300325 001 FRONT WHEEL HUB LEFT
030 2093300325 001 FRONT WHEEL HUB RIGHT
035 2033300051 002 ANTI-FRICTION BEARING REPAIR KIT
050 0239973147 001 SEAL RING LEFT
050 0239973147 001 SEAL RING RIGHT
060 1163340372 001 NUT LEFT
060 1163340372 001 NUT RIGHT
070 000912006176 001 SCREW LEFT
070 000912006176 001 SCREW RIGHT
080 1683570089 001 LOCKING CAP LEFT
080 1683570089 001 LOCKING CAP RIGHT
090 2033300111 001 THRUST ARM LEFT
090 2033300211 001 THRUST ARM RIGHT
100 N910113014000 0019908350 - NUT M14
100 0019908350 001 NUT THRUST ARM TO WHEEL BEARING LEFT M14X1,5
100 0019908350 001 NUT THRUST ARM TO WHEEL BEARING RIGHT M14X1,5
110 2203330071 001 SCREW THRUST STRUT TO LEFT SUPPORT M14X1.5 X 122
110 2203330171 002 SCREW FOR ADJUSTMENT PURPOSES ONLY M14X1,5
110 2203330071 001 SCREW THRUST STRUT TO RIGHT SUPPORT M14X1.5 X 122
120 2203330076 002 WASHER THRUST STRUT TO LEFT SUPPORT
120 2203330076 002 WASHER THRUST STRUT TO RIGHT SUPPORT
130 N910113014000 0019908350 - NUT M14
130 0019908350 001 NUT THRUST STRUT TO LEFT SUPPORT M14X1,5
130 0019908350 001 NUT THRUST STRUT TO RIGHT SUPPORT M14X1,5
140 A2033301911 2033303311
+001 A2033303411 - THRUST ARM *002 *003 *004
140 2033303311 001 CROSS STRUT LEFT *005 *006 *007
140 A2033302011 2033303411
+001 A2033303311 - THRUST ARM *002 *003 *004
140 2033303411 001 CROSS STRUT RIGHT *005 *006 *007
145 2033330914 001 BEARING LEFT STRUT
145 2033330914 001 BEARING RIGHT STRUT
150 N910113014000 0019908350 - NUT M14
150 0019908350 001 NUT CROSS STRUT TO LEFT WHEEL CARRIER M14X1,5
150 0019908350 001 NUT CROSS STRUT TO RIGHT WHEEL CARRIER M14X1,5
160 2203330071 001 SCREW CROSS STRUT TO LEFT INTEGRAL CARRIER M14X1.5 X 122
160 2203330171 002 SCREW FOR ADJUSTMENT PURPOSES ONLY M14X1,5
160 2203330071 001 SCREW CROSS STRUT TO RIGHT INTEGRAL CARRIER M14X1.5 X 122
170 2203330076 002 WASHER CROSS STRUT TO LEFT INTEGRAL CARRIER
170 2203330076 002 WASHER CROSS STRUT TO RIGHT INTEGRAL CARRIER
180 N910113014000 0019908350 - NUT M14
180 0019908350 001 NUT CROSS STRUT TO LEFT INTEGRAL CARRIER M14X1,5
180 0019908350 001 NUT CROSS STRUT TO RIGHT INTEGRAL CARRIER M14X1,5
200 0003300018 004 PIN FOR ADJUSTMENT PURPOSES ONLY
*002 UP TO IDENT NO.: A 377129
*003 UP TO IDENT NO.: F 287021
*004 UP TO IDENT NO.: R 060599
*005 FROM IDENT NO.: A 377130
*006 FROM IDENT NO.: F 287022
*007 FROM IDENT NO.: R 060600
33 FRONT AXLE
Do all worn wheel bearings make noise?
On this topic. In the past I have had other cars need wheel bearing replacements and they always made noise in cornering when they were bad. You could always tell a bearing was bad by listening.
Recently two places, a tire place and sears (doing alignment) told me they thought the car needed new front wheel bearings. One guy showed me a very slight up/down movement in the wheel but no side/side movement. I do not hear any particular noise in cornering which I've heard on many other cars.
So: Has anyone heard of a worn/bad wheel bearing that didn't make any noise?
hello
odd problem.. I have a 2005 C240 rear wheel drive..
I ordered bearings from an online supplier but they where the wrong ones. I got suposedly OEM #203-3300051 (stamped on both bearings) but the outer bearing inner diameter is too small, the inner grease seal OD seems too small also and it does not include the ABS tone ring.
Yet MB dealer confirms this is the right OEM number
Has any one run into this problem?
there is also another part kit I see W0133-1716783 Does any one know about this? it is easily googleable. It looks the same except for a grease tube and clamping nut
Any help would be appreciated.
thanks
thanks
hello
thanks
thanks
1163340372, 2023520165, 2033300051, 2033330914, 2203330171, bearing, bearings, c230, diagram, diagrams, diy, hub, ml430, rear, wheel
