Headlight Washers Not Working
Old Nov 10, 2011 | 08:15 PM
steadystud's Avatar
2003 Mercedes-Benz S500, 2002 Acura MDX Touring
Hi, Very detailed info. I was just wondering if this wouldd also be the same to fix a 2003 S500 (W220) body type?? The mechanic told me that I might have to remove the bumper .. which sounds a little off.... I am trying to use the DIY route. Im trying to get this done tomorrow. Please help.. THe grommet.... #70 do I have to get it at the dealer or can I find it at the Autozone??
Old Apr 20, 2015 | 09:50 AM
Adi88's Avatar
W203 c220 Advangarde
Headlight easy fix!
Hi all!
i failed the national car test in Ireland.
Reason:headlight washer not working!
I got home, checked fuses and conections and they were all fine! Then manually i open the little lid and pulled out the nozzles a few times to give them a bit of "life". Checked again and worked fine! There was no noise from the pump or any sign of power going trough,so be carefull and dont spend alot of money on parts before you try this! Hopefully helps others and save there money! Good luck!
