Oil type for c230k?
1 Post
'05 c230 Kompressor Sport Sedan
Oil type for c230k?
I've read all the oil change threads and they talk about intervals, but there's no mention of oil type other than it's Mobile1. Can anyone clarify exactly which type of oil? Weight?.....thanks.
I do not have the service manual unfortunately. If anyone has a digital copy or knows where I can access one, that'd be awesome.
Thanks a ton. Drive safely.
The 10w-40 semi-synthetic is not MB approved oil, it may damage your engine.
1 Post
CL203, W211
right, now im getting worried, i've got B service coming up in 200 miles and I want the right oil this time, I know I need mobil1 0w40, but does it have to be semi synthetic, or fully synthetic? kthx.
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
As it has been said several times (even on this post):
use SYNTHETIC only
There are other oils brands that can be used other than Mobil 1, here is a list but check your manual to find out what Spec you need it is listed as 229.X
http://www.whnet.com/4x4/oil.html
use SYNTHETIC only
arctic white / 07 w203 ss
i went to the dealer today and told them what car i had... and asked for 0w40 but they told me i should be using 5w40 and thats what i ended up buying.. anyone shed light on this? i've been reading everywhere that it is 0w40
I just recently bought a C230k from a volvo dealership and they changed the oil right before I bought it, so it looks from the window sticker. Should I assume they knew to run synthetic? If I shouldn't just assume this, should I go get a proper oil change with synthetic even if they did just change it? I have heard that if you're supposed to use synthetic that you don't ever want to have anything else in there for oil or it can mess things up.
"Hold it right there sidewinder!" -Chuck Connors as the Rifleman
The oil for Mercedes Benz gasoline vehicles in model year 2005 is Mobil One 0W-40. The oil must conform to Mercedes specfication sheet 229.5. Mobil One 5W-40 does not have the additive package that allows a one year or 13,000 mile change interval.
Check the oil container, it must say MB sheet 229.5, if it only says approved by DaimlerChrysler or other such verbage and does not quote the number, you would do well to avoid it.
There is also a Sheet 229.51 that has been published by Mercedes, however, it is intended for diesel engines. At first Mercedes thought thses oils to be compatable with gasoline engines, but they have now suggested that the 229.5 oils would be more suitable for gasoline engines (petrol for our UK friends.)
Mobil One 0W-40 is one of several dozen oils approved world wide on sheet 229.5, but it is the only one readily available in the USA.
You must also use the Mercedes or Mann fleece (polyester) filter for the extended change interval. The oil must be full synthetic. Conventional and semi-synthetic oils have waxes and varnishes that will create sludge. Engines run with the correct oil and filter will run 200,000 miles with virtually no wear. If the additive package in most synthetic oils is depleated, or if you use conventional oils, your engine will wear, and the expected life will be reduced.
I can understand why a dealer would sell you the wrong product. They are commission salesmen, and if they don't have the proper oil (in qt bottles) they will sell what they have.
1 Post
13,000 mile interval?...seriously? So with this $70 oil change it's actually cheaper than with other cars? $30 per oil change x 3 every 3,000 miles ~ $120. Am i understanding this correctly?
2004.0 C230 Sedan
That being said, make sure to get Mobil 1 0W-40 (MB 229.5 spec) with the proper MB/Mann fleece filter.
I bought my C230 from a Toyota dealer, and they put in conventional 0W-40 with a cheapo filter. I took my car to a MB dealership the day I bought my car and got an oil change.
When buying a used car, IMHO, I always replace all the fluids, and filters so I have a baseline to work from, if you don't have records.
If you can't be absolutely certain the car has synth, dump it.
You can diy for cheap.
This little baby will suck out the oil pronto for 20 bucks.
http://www.boatersworld.com/product/367400017.htm
FYI- there is no fleece filter for M111.
You don't have to use the Mobil 1 0-40.
And in fact some people feel it's crap, had their oil analysed and the result was just ok to mediocre.
Consult the list posted here....and other places many times over.
The lower number extends the range in cold weather.
I live in california so I don't need 0 weight.
I bought oil filters online for less than 10 bucks.
Oil at Kragens $1 a quart after rebate, yes synth.
Vs. the dealer here in San Jose which charges about 300,
I do it for $17. he he.....
I think I will purchase that pump and do it myself, but my question is will that be good enough to rid the car of all the older oil and I can ensure it's all synthetic?
Also I did a quick search for filters and I am wondering if I want the hastings for the c230k at the top of the list is what I need for an 04 c230k sedan.
Check the Hengst thats for 2003-2005.
Try this site.
http://www.autopartsworld.com/Part.a...oil-filter-kit
