No Sound Through Speakers
Old Oct 31, 2002 | 08:08 AM
getchellad's Avatar
02 C320 S.E., 02 BMW 330XI, 00 4Runner
Red face No Sound Through Speakers
I recently got my car back from the shop, after having some minor body work. I was having the work done through a friend of a friend type of situation.
When I got the car back, I'm getting no sound through any of the speaker.s Any ideas where I should start looking to fix this problem?
Thanks,
Adam
Old Oct 31, 2002 | 08:28 AM
JeT's Avatar
JeT
Re: No Sound Through Speakers
Thanks,
Adam
Be more specific...is there power to the HU? Is there any static or a humming noise from the speakers? What body work did they do? They could have inadvertantly disconnected the cables if they were working behind the trim.
Old Oct 31, 2002 | 09:45 AM
getchellad's Avatar
There is power to the sterio, but I'm getting nothing through any of the speakers. You can turn it on to a station, but there is no sound, no humming, no voltage, to any of the four speakers, or the small doors speakers.
Where should I start looking?
Old Oct 31, 2002 | 10:46 AM
jlm's Avatar
jlm
Sounds like the same symptoms as when I installed my Audio 10. I would have to turn on and off the car and the radio several times to find the magic combo to get sound, even though the HU seemed to be working perfectly. Could be that your mechanic did something that will require the fiber optic communications to be re-initialized.
jlm
Old Oct 31, 2002 | 10:55 AM
getchellad's Avatar
[i] Could be that your mechanic did something that will require the fiber optic communications to be re-initialized.
jlm [/B]
Jim, Do I need to take it into the dealer to have this done?
Old Oct 31, 2002 | 11:07 AM
jlm's Avatar
jlm
That's where I went. I don't know if outside shops can get the MB computers to do this. Maybe someone else can answer that.
jlm
Old Oct 31, 2002 | 11:56 AM
antonio's Avatar
2002 C240 Classic
id go to the dealer and just tell them they stopped working. less detail possible will save you money and make them pay for it because its under warranty. but sounds as though maybe the doors were disassembled and the wire connections could be loose. just take it to the dealer and don't say anything. im experienced in this regard.
