Origins of the "Hump" on some '03 Coupes
2010 C300 4matic
Originally posted by MB-BOB
Dude, Maybe you don't have the sunroof in your C320... My sunroof HAS the pop-up deflectors you describe across the entire width of the opening. So, the "stuffy ole farts/geniuses" that designed your car knew of the problem and are up to speed after all. The pop-up Glass panel on the Coupe is a different design, but just not as effective at quelling the buffeting noise.
Re: i HATE that noise!
Originally posted by yodlebenz
i know just what you're talking about. it's a really looooow pulsing sound. it just goes right thru my skull! i only get it between say 30 and 50. not there outside that range. the WORST part is right around 40. then it starts to die down.
any solution for this?
EDIT: See two posts below.
Originally posted by bagwell
my 96 Infiniti had a very small wind deflector when the sunroof was opened the little spoiler pops up...pretty much std on jap cars....I guess the geniuses at MB haven't figured that out yet...my guess is they never ever open the sunroof when testing a car...therefore they couldn't care less...they're prob all stuffy ole farts that leave the windows/sunroof CLOSED.
1 Post
2005 smart cabrio; 2008 Mercedes-Benz B 200
buffeting
Well, if that little device actually reduces or eliminates the buffeting of the Panorama roof in its more "wide open" postions, it's well worth retrofitting to a 2002 or early 2003 car. I'll test drive one at my dealer...when he gets one that has the hump.
All their presently-in-stock 2003s have not been humped
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
What noise?!! Come on you guys there has not been one post complaining about the wind noise until this little pimply thing was noticed (actually can't confirm that as I didn't search). I don't seem to have the pusing noise and if I do I haven't noticed it...maybe I'm deaf!
You'd think MB would have been a bit more innovative after 3 years of making the coupe...like putting in an auto close for the pan (or have they done that?).
#32
1 Post
buffeting
Open the panorama roof fully, keep both side windows closed tightly and drive around at between 40 and 80 km/h. If you don't hear any buffeting whatsoever I'd be amazed. Drive into and away from winds if it's a windy day.
If you can't hear any buffeting under any conditions and you don't have the hump, you should have your hearing tested![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
The buffeting sensation is like when an "import scene" car with huge boom boxes pulls up to you at a light - a very low frequency pulsation that drills right into the ears. The buffeting is caused by pressure waves in the cabin being created when the sheet of air coming over the hood and wind deflector panel descends onto all or part of the open roof area. It seems as though the flip up wind deflector is optimised for higher speeds...but from 40 to 80 km/h is a typical speed in urban areas, so it makes it difficult to keep the roof wide open in such areas. Cracking open one or both side windows will make it go away, but then the wind noise from these becomes obtrusive.
#33
I agree with MikeT, just open your windows a little bit. If you really want to get trick open one more than the other and you will cancel out two resonances:p. You can also close the sunroof a little to get less buffeting.
#34
2008 VW GTI
Originally posted by JeT
What noise?!! I don't seem to have the pusing noise and if I do I haven't noticed it...maybe I'm deaf!
It doesn't bother me in the front, I pretend it's bass coming from the magic subwoofer.
#35
2002 C230 Coupe Black/Charcoal C5 C7 Auto
yeah actually when i have my pana roof open i leave a crack open on my left/right window and really dont have the issue. I'd rather do that then have a "hump" on top of my car (that thing dont look right). HOWEVER, I would like to know if anyone (someone who actually own their car and have skillz) want to try to put the seatbelt extender........that however I would love to have.
#37
#38
Erik
#39
2008 VW GTI
Originally posted by tifosiv122
They said it couldn't be done. I am not sure how many people are willing to take apart their seatbelt units.
Erik
Erik
It appears that the entire seatbelt height adjuster assembly has been revised. The whole thing looks different and not just the addition of the clip. I played with it for a few minutes and I don't think it's worth the aggravation to retrofit. It didn't seem to make much of an improvement. Late'03 owners may have other opinions as to whether or not this is a "must-have".
#40
Erik
#41
C230K
Every car I have owned with a sunroof made noise. 1987 Accord LXI, 1990 VW Corrado, 1997 VW Jetta, and 2000 Passat. The all made noise at certain speeds and you had to keep a window cracked to stop it.
#43
C230K
Does anybody know the MB part # for the wind deflector (hump) described in this thread? I have the exact same problems from 35-55mph. If I stick a couple of fingers up through the sunroof no more than an inch into the airstream on the front edge of the sunroof opening it completely goes away. I know you can crack a side window and it goes away but then you have a different noise to deal with.
#44
I've been to dealers in Seattle and Portland, and they both say there is no separate part number. It is the way the roof is made now. If you replace the roof glass, you get the bump.
jlm
jlm
#46
2002 C230 Kompressor coupe, white
my roof has the hump, (they replaced it with an 03 roof) personally i cant stand the look of it, i prefer the smooth look i had before (plus everyone thinks its a 1.8L), as for the wind/reception, its not that much of a difference to me, definately not worth 269 dollars
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#48
1 Post
hump
Originally posted by UStifosi
I contacted a local dealer who thinks the correct part # is 203 780 0136. Cost #269.50!!!!
#49
Just got my '02 C230 retrofitted with both the new front glass with the hump and the new seat belt guides.
The hump on the glass makes the sunroof usable with the windows closed - and, it's not as large as the older glued on humps. It's now integrated into the glass frame.
The seatbelt guides make it a whole lot easier to get to the seatbelts and they can be pushed down out of the way to allow passengers into the back (this doesn't happen very often). Plus it keeps the seatbelt from rubbing on my neck - that's the best part!!
Oh, and my dealer did this all at no cost!!
