kw / hp / torque?
What car would statistically be faster from 0-100km/h.
Car A - 170kw and 210 nm torque OR
Car B - 145kw and 280 nm torque?
Not taking weight into account, let us assume they weigh in the same, stock standard cars with these specs..
A car needs torque for pulling heavy loads up hills etc, but what exactly makes it fast? KW or torque? Just trying to understand the science behind it all..
Thanks,
Converting to HP and lb/ft for my uncouth American brain, there is 33HP difference favoring Car A - but about 52 lb/ft torque difference favoring Car B. As torque is a function of power and engine speed, I'd expect Car A to be making those numbers at a higher RPM than Car B makes it's numbers. Hence why I feel Car B would take the 0-60 sprint, but that Car A might tie it up in a standard drag race.
But one key variable you didn't mention is if the gearing is the same on each car. If the transmission and final drive ratios are identical for both cars, I guarantee that Car B will be faster 0-100 every time. It has more mechanical advantage. But if Car A has a shorter (numerically higher) final drive ratio it might be exactly as fast or even faster than Car B in the 0-100km/h sprint.
Or do you already know the answer, and this is just a trick question to trip us up...?
