DIY C230K sedan oil change W203
Old Dec 3, 2007 | 04:39 PM
Taiwanese's Avatar
2003 C230
Originally Posted by mike82y
did you try the following method?
turn your key to position 1
change the screen to show the current milage
press reset 3 times, (fast)
"beep"
turn your key to position 2
oops sorry.. I just ran to the car and check again..
you can only reset the service with this method on w211.. not w203
mike
I also ran out to the car just now. You are right. It did not work. Thanks anyway.
Maybe I can't reset it until it's service B due? Now is Service B in 1200 miles.
Old Dec 3, 2007 | 04:44 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I guess Taiwanese do kickass?!
Old Dec 3, 2007 | 05:08 PM
Taiwanese's Avatar
2003 C230
"beep"
mike
https://mbworld.org/forums/showthrea...=1#post2534100
it worked:
ignition on, not running
Remaining miles to service displayed
Press and hold the dash reset pushbutton
(ask you do you want to reset)
DONE
Old Jan 24, 2008 | 09:05 PM
zoomie's Avatar
'05 c230 Kompressor Sport Sedan
Wow, this is superduper helpful! Thank you so much!!! even a noob who doesn't know an engine from a wheel can can do this....maybe. Where do i get replacement o-rings from?
Old Jan 24, 2008 | 09:22 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
They come with the new oil filter.
Old Jan 24, 2008 | 09:24 PM
aznmode's Avatar
2010 c300
If you get the oil filter from the dealer it comes with all 3 rings inside the box.
I've just recently done this DYI on my c230 and it took me a while to get the oil out the first time. Before the oil change my cluster said I was short 1 qt. So I took my time to let the oil settle on the bottom and pump. I did this repeatedly for about 45 min to make sure I got all the oil out. My dumba$$ didnt have the right tool either so that added more time trying to get the filter unscrewed.
This method is so much easier!! Thanks to this DYI guide.
Old Jan 25, 2008 | 09:45 AM
  #32
RedKen06C230's Avatar
c230 06
be a man and get underneath and drain the oil that way.... there is a drain plug just like everyother car on the planet... u dont need a extractor
Old Jan 25, 2008 | 09:55 AM
  #33
EV0LVE's Avatar
F10
after doing some search here and other mbz forums, i believe that using an oil extractor actually removes more oil and sediment than draining. you do it your way, we'll do it ours.
for the op, much props for the effort of doing this and contributing to the board.
Old Jan 25, 2008 | 12:05 PM
  #34
Taiwanese's Avatar
2003 C230
Thank you for the kind words. You are so welcome.
drain vs. extract?
As long as you change your oil, either way is fine.
I have drained many times in my younger years. As of now using oil extractor is good enough for me.
cheers.....
Old Jan 25, 2008 | 12:14 PM
  #35
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
The test has been conducted by johnand. Both methods removes the same amount of oil.
Old Jan 25, 2008 | 01:30 PM
  #36
aznmode's Avatar
2010 c300
What! There's a drain plug underneath the car? WTF?
Old Feb 10, 2008 | 12:10 AM
  #37
Sponger's Avatar
I haven't posted in a loooonng time. Thanks for the helpful DIY. I did the following last night:
-oil change using Mobil 1 0-40 synthetic
-Hengst oil filter
-Hengst air filter
-new charcoal in-cabin filter
-Mityvac fluid (dispenser and evacuator)
I also had a buddy do an alignment with the 19s. Bought all the parts from buymbparts.com and it was shipped to my house in two days. Got the Mityvac
from tooltopia.com. It was under $70 shipped. I had a really good buying experience from both sites -- fast shipping and lowest prices I could find.
Can't wait to do this again
Old Feb 10, 2008 | 01:31 AM
  #38
06c230hwd's Avatar
06' C230SS
ive tried everything.. but i can not find a fluid level on my dash
three fast clicks of the reset button gets me into bat volt., soft vers., etc. but i cant find the darn fluid level
Old Feb 10, 2008 | 08:04 AM
  #39
wingless's Avatar
Use the odometer / trip menu, turn the ignition on, do not start, cycle though the sub-menus, there is a level check option. The vehicle must be warm and have sat long enough or it doesn't work.
Old Feb 10, 2008 | 01:00 PM
  #40
06c230hwd's Avatar
06' C230SS
the vehicle must be warm for the level to show up? i think you're nutso!
Old Feb 10, 2008 | 08:49 PM
  #41
wingless's Avatar
My wife would agree.
Yes, the vehicle MUST have sat long enough and it SHOULD be warm.
You're welcome for the menu sequence.
Old Feb 10, 2008 | 09:31 PM
  #42
06c230hwd's Avatar
06' C230SS
Well like I tell my girl, it takes one to know one. And in your case, she married you, so cookoo cookoo lol... Anyways, yeah thanks for the advice, took a 10 mile round trip earlier to the bank and back.. car sat for about 5 maybe 6 minutes and I tried to cycle through and find a level. NOTHING! Maybe it's a user error but I'm quite confident I can read and I'm following directions properly.. so who knows! Maybe I've got a dipstick, I'll look tomorrow!
Old Feb 10, 2008 | 10:14 PM
  #43
tyronewheatley's Avatar
w203
VERY good post! thanks!
Old Feb 14, 2008 | 06:53 AM
  #44
jes_bad's Avatar
2003 C230 Sport
Thumbs up Thanks!
Thanks for the info! I'm going to give this a shot this weekend. I hope to find the oil and filter from Autozone or Discount Autoparts.
- Jes
Old Feb 14, 2008 | 11:40 AM
  #45
06c230hwd's Avatar
06' C230SS
954 eh? what year did you graduate highschool jes_bad?
Old Apr 4, 2008 | 12:19 AM
  #46
Benzino's Avatar
03 c230
5w-40 ok?
Old Apr 4, 2008 | 12:29 AM
  #47
coin's Avatar
'06 CLK500
Originally Posted by Benzino
5w-40 ok?
If you check your manual, it will show you what's the recommended oil to use.
Old Apr 8, 2008 | 09:49 PM
  #48
Boosted230's Avatar
2002 c230 Kompressor Coupe
Has anyone done their oil change without the extractor? I'm used to doing it by draining the oil via the drain plug..but after reading this thread, apparently their is a plastic shield that needs removing to access the oil drain plug?
Any insight on this would be helpful. Thanks!
Old Apr 9, 2008 | 09:32 AM
  #49
tommy's Avatar
2004 Civic Si. FWD for the Win!
Like everything else on this car, you would have to remove a plastic shield to get to anything underneath the chassis. They're easy to remove.
I'm suprised no one has said this; you should really be torquing the fliter back to spec, so that you don't overtighten, like someone else did above. Yes, you'll need to buy a torque wrench, but you should have one anyway for your lugbolts.
I've been doing the topsider way for years now. I have no idea other than stubbornness why you'd go the old-fashioned way on these cars.
Old Apr 9, 2008 | 09:51 AM
  #50
e1000's Avatar
a quarter mile at a time
BTW - the 2006+ M272 cars do NOT display the oil level in the computer menu.
You have already rated this thread Rating: Thread Rating: 19 votes, 5.00 average.
