anyone have problems with mtec hid?
If I allow the bulbs to get up to full operating intensity, turn off the lights, and then turn them back on, all of the errors go away. The errors return the next time I turn on the lights. After three complete engine start-stop cycles (key on, engine start, lights on, lights off, engine off, key removed), the "check engine" light comes on and stays on for any additional start-stop cycles.Obviously, this ruins the MB experience. Does anyone here know what might cause all of this? Most other people seem to be error-free with this same installation. Thanks ahead of time for your help. I'm new to all of this.
I have a 2001 C240 sedan and still equipped with Halogen.
Do you mind if I ask the following questions?
1) Did the xenon bulbs fit correctly on the halogen socket. What I mean is that when you take out the H7 Halogen bulb, do you just insert the xenon bulb and itt will fit perfectly?
2) Mine still comes with the halogen headlamp housing and I would presume that it is using reflector type housing (I cannot be sure). Did you have to do any modification at all to your housing or did you just insert the xenon bulb using your original halogen housing? I wanted to make sure that you can use a xenon bulb on a halogen headlamp housing without probably causing a lot of distraction to oncoming traffic. From what I have read, xenon bulbs are supposed to use projector type housing (again I cannot be sure).
3) Where did you attach the ballast?
4) Was there any complications on the wiring at all?
Thanks for all your help.
2) you're correct, regular housings might produce a glare that can blind on coming traffic and the cars in front of you. it's better to use a projector for your hid setup as you can aim the cutoff line
3) i ziptied one to my car, and screwed in the other.
4) nope, plug and play. just connect the plugs to the correct socket and you should be fine
Thanks again.
I have MTEC HID 6000K kit one week ago installed and the look great!The installation took me about 1 hour.You don't have to cut anything,all cables fit exactly.It is very very simple to install them.No fault error!The only thing that will take you more time is to find a good place for the ballasts,because there is not enough space in W203.
Star_lunatic
