Need help! urgent
Old Nov 7, 2002 | 06:24 PM
Diego's Avatar
C 230 Kompressor 2002
Need help! urgent
I have unscrew all three screw from the door panel, and unclipped all those clips but I just can't take the door panel off...
I have already taken the U-shaped plastic trim but I have way of taking the door off!! i am stuck so please try to help me! i am doing that right now! thanks!
Old Nov 7, 2002 | 06:45 PM
KWiK's Avatar
2002 C230 : 2007 C230
after all screws and clips are removed, the door panel should lift up. This is easier if the window is down. The panel sometimes fits very tight along the window seal. If you could post a picture of your progress, it would help in answering your question.
good luck.
Old Nov 7, 2002 | 07:03 PM
Diego's Avatar
I will try to post some pics, but i don't have a camera right now! so i will try to explain you was going on!
i look inside the door panel i saw a metal string attached to the door handle! i am no sure if I have to pull off the string from there. I also tried to pull the panel from the bottom but i can not force it cause I could break it. ( i looked inside it seems to be glued to the other part)
Old Nov 7, 2002 | 07:22 PM
KWiK's Avatar
There should be a release on the backside of the handle. What are you doing that you need the door panel removed? If just changing speakers, leave the cable connected.
Pulled the bottom in which direction? I thought you already released the clips? Pull up from the top where the panel meets the window.
Are you sure you got all the clips?
Old Nov 7, 2002 | 07:36 PM
getchellad's Avatar
02 C320 S.E., 02 BMW 330XI, 00 4Runner
Lift Hard
Don't ask why, but I've had the doors off more times then I would like to admit. After you've undone the 3 torx screws and unsapped the bottom and outside lower edge of the doors, you really have to lift hard. Grab the door panel at the top on the latch side, and lift hard. The panel will either seperate from the window rubber trim that's holding it, or it will come up with the trim. You'll have a couple of wires to undo, depending on the door your working on, and the wire for the door latch will need to be undone aswell.
Good luck.
