How much does brake pad install usually run for??
Old Nov 27, 2007 | 01:25 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
recently i purchased a front set of Hawk pad for my coupe for 80 bux and 20bux for shipping, so around 100bux total
and install them for another $100
total of 200 does it sound right??
Old Nov 27, 2007 | 03:53 AM
StealthShinobi's Avatar
10/15/07 In a week or two it will be a 2002 C240
yes i would like to know as well..my brake warning just came on
edit: where did you buy your bads btw?
Cam
Old Nov 27, 2007 | 04:07 AM
KIRA's Avatar
Cam
tirerack.com
which mean you gonna need new sensor too from the dealer...
Old Nov 27, 2007 | 12:26 PM
romz's Avatar
2001 C240
My front breaks from the dealer ran me about 200 installed. so it sounds about right.
Old Nov 27, 2007 | 12:50 PM
moosejaw's Avatar
none
An hours worth of labor should be around 45-60 bucks at an independent shop. Dealer would probably charge you an $100+.
Old Nov 27, 2007 | 03:18 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
I got charged for 90 for installing both front and rear
Old Nov 27, 2007 | 04:45 PM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
I just bought new front pads, rotors, and sensors from the dealership. I was thinking of installing them myself, but felt too lazy. I had my Service Advisor at the dealership install them for $100.00.
Old Nov 27, 2007 | 05:05 PM
KIRA's Avatar
for everything??
Old Nov 27, 2007 | 05:30 PM
bcaruso's Avatar
08 E63 Soon
Just an FYI. Installation is less than 2 minutes per side once the wheel is off. If you are a little handy you can save a lot of money and install the pads yourself. The installation procedure is so insanely easy it is not funny. Pads are held in with two pins that pop out and the pad slides right out.
I understand if you are not handy so figure a shop will charge you a minimum of one hour labor to do the job for you. Good luck with it.
Old Nov 27, 2007 | 08:01 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
Forgot To Mention, 90 Was For Installing Both F+r Rotors And Pads
Old Nov 27, 2007 | 11:55 PM
rubenl's Avatar
2005 C230 SS, 2000 1.8t Passat, Crown Vic with lights on roof
save your $, do it yourself, it is very simple...
Old Nov 28, 2007 | 03:38 PM
aznmode's Avatar
2010 c300
Wow good to know it's easy. So no need for bleeding or clamping? What bout greasing?
Old Nov 28, 2007 | 04:09 PM
KIRA's Avatar
lol i MAY have no idea how easy it would be, but i still don't trust myself for doing ANY BRAKING things on the car because IS FOR STOPPING!!
i don't want after i ****ed up my ****ing car because i mess up changing my brake pad
Old Nov 28, 2007 | 07:33 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
The only reason it would be difficult to do yourself would be if you have let them wear to the point that the rotor has a large lip on both sides and the piston will need to be compressed before you can slide the pads out. I just did a buddies car two weeks ago that was like that. Not that is was difficult, but you had to use a screw driver or small pry bry to wiggle the pads apart to get the piston to compress a little. Added maybe 15 minutes a hub to an hour long job. Now if you plan on replacing the rotors at the same time, add another hour as you will need to remove the calipers to get the old rotors off and the new ones on. If you have over 20k miles on the old rotors, I would replace them as you have probably used up more than half of them anyway.
And while you are at it, you can add another couple of hours and have custom painted calipers to boot!
Old Nov 28, 2007 | 07:40 PM
rlee02135's Avatar
2004 C32 ///AMG
any gas station garage can do the brakes...should be no more than $50
