How many C230 owners considered the C240?
I kinda agree with Chrono with a twist
It's OK for the C240 to stay but IMHO I would prefer that it is replaced by a new C230K Sedan along with the sport coupe. It may keep the cost down and give us better selections.
Peace
Peace
Originally posted by chronopassion
However, there is really nothing to connect a VW Corrado with the current MB C230K either internally or externally beyond the hatch nature. I can post an image of a Hyundai and your C240 and say they were twins. However, that is as silly as your statement about the C230 and the Corrado.
maybe info?
today I picked up my 03 c32. While waiting I was thinking of buying a c230 for rain and walmart days. Spoted one and one only that had a strange black plastic ridge about 6" long just ahead of the sunroof. It also had badges on the front fenders " 1.8 " Does anyone know about this feature. My dealer is brainless!
2005 smart cabrio; 2008 Mercedes-Benz B 200
Stepback vs Hatchback
Originally posted by SoCal240/6
1) Even with balance shafts, its difficult to get a really smooth 4 cylinder. I'm sure the 1.8 improves on the 2.3's NVH, but there was a lot of room for improvement there. It could be significantly improved but still not up to a 6 cylinder.
For a 6, the smoothest arrangement by far is the inline configuration, something abandoned by M-B 5 years ago on the grounds of cost and safety. If you don't know what I'm getting at, bear with me.
The second most smooth 6 cylinder configuration is a V-6 with a 60 degree spacing between cylinder banks. Such engines are even-firing and inherently more vibration free than any other Vee arrangement involving 6 cylinders.
One of the least smooth 6 cylinder configurations is that used in the Mercedes-Benz V-6s, namely 90 degree. The VW VR-6 is probably worse, though.
Why did M-B go to V-6 engines in its smaller cars, instead of the inline 6? One reason: the V-6 engine block is a lot shorter than an IL-6, resulting in far more programmable crush space, at a premium in a small car like the C. But why did M-B go to the sub-optimal 90 degrees for its V-6? Economics. It's simpler and cheaper for them to use the same block boring equipment that they use to make their V-8 engines (which have a 90 degree spacing, that being optimal for a V-8). The Mercedes-Benz V-6 is - in principle - a V-8 with two cylinders lopped off. The economy of scale in producing similar engine internal parts for use in the V-6 and V-8 engines is also compelling.
Mercedes-Benz was aware of the design compromises in creating its 90 degree V-6, and designed into it a counter-rotating balance shaft to counteract its unbalanced architecture. Notwithstanding that, it's relatively easy when driving a C 240 to detect its slight roughness, especially at idle, but at certain other points in the rev range too. Compared to a 60 degree V-6, or especially to an inline 6, it's a rough engine.
The new M271 IL-4 engine has two counter-rotating Lanchester balancers just above its sump. I would not be surprised if the new IL-4 is as smooth as, if not smoother than, the V-6 in the C 240 and C 320. I'll test drive one or two soon to see for myself. Another thing the new engine has going for it over the V-6 engines is the far lower reciprocating mass. Not to mention superior power and way better fuel economy.
Now, to the original purpose of this thread: we considered a C 240 6 speed, which is a nice car. What I did not like about it was the fuel-inefficient V-6 engine. Well, the droopy headlights were a bit of a turn-off too (the bi-xenons are growing on me). The 18 valve V-6 engine is way behind current technology, and will be updated to 24 V and become more fuel-efficient next year. But overall, the C 230 K was far better value - ours cost a tick over $22K US with panorama roof and rain sensor, whereas the Classic C 240 would have cost about $3000 US more. The C 230 K is virtually as roomy as the C 240, and much more practical for us due to the hatch. Despite having the old M111 engine in it, the car is adequately smooth for us. It is also far more powerful and fuel efficient than the V6. Had the C 200 K been sold here, we might have got it instead. I wish M-B would put the M 271 engine in the W 203 body and not just the CL 203. Maybe in Canada they will; we already get the "economy" Classic version of the W203...
Re: Stepback vs Hatchback
Originally posted by Mike T.
Well, it's also difficult to look intelligent when generalising about 6 cylinder engines being smoother than 4s, unless one specifies the layout of those 6 cylinders.
True, an inline 6 is the smoothest configuration. But even the less smooth configurations are still generally smoother than a 4 banger.
I don't think the MB V-6 is a "rough engine" compared to other 6s. We drove the 325/330 when we were shopping . . . those are the ultimate in smooth inline 6s. Yes, they were smoother than the MB - but I'd hardly call the MB 6 a "rough engine" in comparison.
#32
You guys can discuss engineering principle all you want...
As for smoothness, I can place a clear glass filled with water on the intake plenum of my 3.2L V6, and with it running at idle, see no ripples in the surface of the water. I've done this with every car I've owned, just for grins. The only car that performed better was the 1.6L I4 in my '77 Honda Accord... That engine was a smooth as a sewing machine.
As for fuel efficiency, I'm currently getting 24mpg with my C320. This is equivalent to my previous daily driver, in spite of the fact that the C320 weighs 340 lbs more, has 700ml more displacement, 53 more HP and an automatic transmission, versus the 2.5L V6/5spd manny in my previous ride.
As for the original question in this thread, obviously I considered a C320, because I wound up buying one. I also seriously considered the C230K SportCoupe. But I never once considered the C240, not even for a second... If I wanted 168 hp, I would have stuck with my previous car and it's 165.
#33
2002 Mercedes C240 Desert Silver Java Interior
Perhaps I shouldn't be posting this, but I am quite tired of reading all of these threads about how the C240 sucks. It is what I drive and I am really enjoying it. Since performance has never been an issue for me, it is the ideal C-Class for me.
A little more about me now: I am 23 years old, Hispanic, and my own personal income (with bonuses received at the end of the year) approaches 92,000 (well, about 10K less). I may be wrong, but all of you 46 year old men driving the C-Coupe *****ing that your car is far better than the C240 are a bunch of losers. A MAN APPROACHING 50 YEARS OF AGE SHOULD BE DRIVING SOMETHING FAR BETTER (and please no petty responses by those of you in your 30's, its just as bad). So stop spending all of your time here trying to make your fragile egos feel better by downing the C240, and try figuring out why there are men half your age out there earning more and driving better.
Sorry, I really did like this forum, but the incessant *****ing is far to much for me.
#34
2003 Citron Green C230KMT
Re: How many C230 owners considered the C240?
When I was looking at the C230, I also took a look at the C240 but was terribly disappointed in the C240's performance. I then tried out the C320 which felt much more similar to the C230 than the C240. Is there anybody else out there that thinks Mercedes could do away completely with the C240 and move on with their better performing C230 and C320's?
CP
P.S. Obviously, virtually anyone who bought the C230 could have just as easily afforded the C240, so cost is obviously not an issue for everyone who opted for the C230.
CP
lhoang,
Gee, thanks for a very intelligent response. Good to know that Mercedes does not discriminate selling you a car contingent on an IQ exam.
The point remains on whether or not the C320 is truly the only other iteration needed in the US C Class series besides the C230. The C240, in my opinion, was very similar to a standard (non-V6) Honda Accord in performance. For Mercedes to keep their prestige, they probably should dump the C240 or change it around.
lhoang,
#35
Originally posted by potatobbq
Actually, I have to admit the C230K does resemble the VW Corrado from the pic Socal240/6's sig... Look at the lines of the two cars... almost every single body panel is the same shape, except the VW is just boxier. I really can't think of a Hyundai that resembles the C240.
i am not saying they look identical but the front headlights can look similar, and the Hyundai comes standard with projector headlights!
#37
#38
#39
From a Hatchback owner??? Wow. What a snob!
Although I'm glad that there are others that agree with me on the concept that MB needs to watch how downmarket it goes in the US to protect its prestige image. Definately agree there.
MBs prestige seems to have done fine with small sedans - the C240 handily outperforms its predecessors, the 190e and the C220. Given that fact, I doubt that the C240 hurts MBs image in the US - its a clear improvement on its precedessors. We could debate whether the C240 hurts MB's image in the US- but I think the answer is pretty clear. (In any event, MB's image in the US is not that of a performance car maker).
MB's reproduction of a 1990 Corrado Hatchback is probably a better debate, if you want to talk about going downmarket and MB "keeping their prestige." 1990 Corrado - 1.8 liter supercharged 4 cylinder, 0-60 in 7.5 seconds, see the pic below for what it looked like. Look and sound familiar???
Finally, please check your Terms of Use:
"You agree, through your use of the Discussion Forums, that you will not post any material which is knowingly false and/or defamatory, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening, invasive of a person's privacy, or otherwise violative of any law."
In this particular case, I believe your remark out of the blue about people's C240s is patently "Harassing," possibly seen as "abusive" by the receiving party, and provoking of an argument. Further, IMO, it is meant to be "defamatory" to all members who drive the C240, and given the intentional nature of it also "harassing" and confrontational, at minimum and possibly "hateful," as well.
now thats out of the way, with an attitude like yours about gas, is why this country keeps consuming natural resources and doesnt conserve let alone worry about it. before you say it, i could buy an electric car, or a hybrid, but didnt. i did get a car which is more economical, rated ULEV, with all the features and options i wanted in a down market green hatchback mercedes-benz.
plus this whole hatchback thing with you keeps me wondering, "what will he say next" and you never fail me. when i think youve said it all and pushed all limits, you keep raising the bar for yourself with your comments and quotes. the C230 being MB's reproduction of the 1990 Corrado is you being "inaccurate and knowingly false". though your never taking into account other peoples opinion or even keeping your mouth shut and doing us all a favor by not responding to a post (hateful), when all you have to say is bull$**t (abusive and profane). apply for head of the passenger car division at DCX, then you can make the changes you see fit (harassing)! then again, maybe you will one day change your attitude (inaccurate and knowingly false).
#40
Re: C 230 K prices
Originally posted by BlackC230Coupe
how can someone get a C230 for 22k with options if the base price of the car is 26k?
Sure, there's no free services for 4 years up here, but that's worth exactly $1200 CDN at the rate we drive, or $750 US total.
When we bought our C 230 K in May, the base price was under $34,000 CDN, which at the time was the equivalent of $21,100 US. The Panorama roof and wipers together cost $2180 CDN ($1350 US) - total about $22.4K US.
That Hyundai is scary-looking. Rather like a mutant C 240, looking for revenge on the C 230 K
I like the better fuel efficiency of the C 230 K - ours gets over 38 MPG US driven gently at 90 km/h on the highway, and about 35 driven normally. The 4 cylinder engine is acceptably smooth for a car of this type. The new M 271 engine is both smoother and about 10% more fuel efficient than the 2.3. Using fewer resuurces is better for the earth, good for the karma.
Congrats to the young gent that is driving a C 240 and is proud of his high income. Remember though that not all people gauge their success in life and their self-worth by what they own or how conspicuous their consumption is.
Peace and cheers,
#41
Nevermind
Actually, its not at all. Generally speaking, a 6 cylinder automotive engine is going to be smoother than a 4 cyl auto engine, regardless of whether the 6 is a V, inline, boxer, etc.
Keep working on that wonderful evolving signature of yours. You're bound to get it right one of these days
#42
#43
Re: Nevermind
Ah, change the terms of reference, eh? Not so fast. Back to the point: . . . And this is what your earlier post was about, speculating that the new M-B 4 was not going to approach the M112 for smoothness. I don't see why that should be the case. Mercedes-Benz claims the M 271 is as smooth as their V-6. I'm going to try a couple for myself to see whether it's true or not. And that is why your generalisation about M-B 4s vs. M-B 6s was ill-informed.
All I said was that it would be possible for MB to significantly improve the NVH of the 2.3, yet still not be as smooth as the V6. Average reading comprehension skills would reveal that the sentence does NOT say or predict that the 1.8 won't be as smooth as smoother than the V6, but that the point of the sentence is that there is a huge gap between the old 2.3 and the V6.
I don't know if the 1.8 is as smooth as the V6. MB may claim it is, but they claim a lot of things that are not true. But, its possible, with enough balance shafts, carefully engineered engine mounts, sound deadening, etc. a particular 4 can certainly be made to approach or surpass the smoothness of a particular 6. I never said otherwise. Yet, if that were to be the case in this particular instance, MB has made dozens of different 4s and dozens of different 6s over the years and my generalization still stands:
Generally, MB 6s are smoother than MB 4s.
(My other point also stands: No matter how smooth a 1.8 4 can be made to feel, barring a major crisis of epic proportions, a 1.8 liter 4 banger will NEVER power a C sedan in the US. The US market just expects/demands more than that - right or wrong, its just the way it is).
#45
c230k vs c240
The c230k is the only Mercedes that I considered. I was looking for the best hatchback I could get and the c230k was almost perfect for what I wanted. The fact that it was a Mercedes was at first a negative and an embarrassment for me. I was concerned about MB snob effect backlash. But, I have gotten over that and am now happy to be a Mercedes owner. The c230k is a fine car. It meets my requirements: 2 door, hatchback, sporty, fun to drive, not too many on the road, solid feel, good fuel efficiency. Love it.
Deb
ps. I don't know why you all don't just ignore SoCal240/6.
Deb
#46
let us see
1) Even with balance shafts, its difficult to get a really smooth 4 cylinder. I'm sure the 1.8 improves on the 2.3's NVH (auto engineering term, "noise, vibration and harshness"), but there was a lot of room for improvement there. It could be significantly improved but still not up to a 6 cylinder.
If you think others' comprehension skills are poor when reading your stuff, perhaps instead of complaining, you should strive to achieve some decently clear writing skills. I notice that you throw this accusation around a lot. EVERYONE apparently misunderstands you.
Is it us, or is it you?
What, no update of the signature today? Come on, this one's a day old already.
#47
Re: Re: C 230 K prices
Simple. I live in Canada. We get better deals on Benzes. Come up here and buy a C 32 for under $42 K US. Just don't try to take it back to the USA - they won't let you unless you pay the difference between CDN and USA prices to M-B Canada.
#49
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
I am a master of subtlety - which includes being able to adjust it to suit the reading audience.
You already have the attitude down...think about it.
JER <COUGH>
#50
2002 C240 Classic - Orion Blue Beast!!
I can't really blame SoCal for some of things he says on this board. Some of you guys are just too much. I will never understand why the c240 gets so much criticism from PEOPLE WHO DO NOT EVEN OWN ONE!!!
I think that 230 owners are just trying to give the 240 a bad name because they are upset that the 240 doesn't get pi$$ed on in the media like their "downmarket" hatch does.
And I think 320 owners are just trying to make themselves feel better about spending an extra 10k on 50 more hp. Because really, that is the only fundamental difference btwn a 240 and 320. Oh sorry, digital climate controls are different too. Yeah, that's a big one. How could I forget that?
SoCal, keep up the good fight for us 240 owners. I know how you feel, and I stand behind you!
