should i get spacers?
What do u guys think??? i know putting them on would make my sides more aggressive, make the rear tire "flush" with the wheel arch opening. HOWEVER, im concerned that it might make the car look "Awkward" when viewed from the rear coz my wheels are flush on the sides like a 255, but my tires arent that Wide....
Any opinions? Have any one of u done this mod? Thanks.
hey buell....u have spacers on ur coupe right???? how many mm are they? and what size tires ru using? h&r lists that the wheel bolts should b extended "half" of the spacer's thickness...so does that mean.....7.5mm longer wheel bolts for 15mm spacers???????????????
i cant afford to make a mistake on this, coz im halfway round d globe and ive got 2buy the spacers there in the U.S., so its gonna be pricey freightwise if i make a mistake with these 15mm spacers.....helpppppppppp me guys!
Also, you should get the correct bolts for the type of wheel that you have.
anyone got pics for the rear wheels with spacers--10mm--15mm? especially those with 225 or 205 rear tires. i want to c how theyd luk like when viewd from the rear. tnx.
you can kinda guess how, put the handle side of the bat in the fender between the tire and push up and roll. maybe i should have used some heat, i think that would have helped a bunch, but didn't want to cause damage or an unequal shape. oh well, that was about a year ago and 3 sets of wheels later. i'm happy with my current set.
Umm i also plan to order from Autoclass, so presumably, theyll know what kind of bolts i need right???
i think ill try 15mm first for an equivalent of a 255mm tire look.
if ill take 20mm...then that equates to a 265mm lukin tire,right?
Anyway.....if i make a mistake on this..........DHL or FedEx 's gonna ripp me off with roundtrip freight charges halfway round d globe from the Phils to U.S. hehehe
Hey Lhoang, since uve tried putting on rear wheel spacers on 225 tires?? dont they look weird??? wen viewd frm the rear on those skinny tires? I am still quite confused whether to put spacers or not.
I dont plan to lower my car, and "fender rolling" is "UNKNOWN" in my country. So those 15mm spacers better b good!
if u do not go with this, i think you will be deeply disappointed. i know its only 5mm, but your puting on a spacer anyways. spend the money once and spend it wisely. i have had 3 set of spacers and have spent money more than once. i am just trying to give u my knowledge and not allow u to make a mistake.
another way to look at it the 20mm is thicker, so more durable. either or they will both be safe.
If so, hope that went well.
Anyway you can put a net of 265 in the rear well, that is about it.
So you can choose either 15 or 20mm on your 225s. You are right with skinny tires (225) you might not want to "overdo" it, so 15 might actually look better, though less extreme than 20.
15 is an absolutely sure thing for fit.
