tele-aid/GPS antenna location
Old Nov 11, 2002 | 02:07 PM
E320's Avatar
Hi guys I just need to know where is the location of the tele/GPS antenna on W203?I'm gonna use a W203 gps antenna on retrofitting a comand.
Old Nov 11, 2002 | 02:13 PM
patronus's Avatar
2001 C240 / 6-speed
Top center of the rear window.
Old Nov 11, 2002 | 02:45 PM
MB-BOB's Avatar
Admin Alumni
See Garage
I would call the dealer and ask someone in service who knows for sure. That little stub antenna on the rear glass serves either Tele-Aid or GPS, but not necessarily both. I want to write that I read about another antenna (maybe a back-up) in the trunk or roof headliner, but I'm not sure. I say this, because someone once quoted a salesperson who said the system would still function even if the car rolled over and broke-off the stalk.
Anyone else recall this?
Old Nov 11, 2002 | 03:59 PM
getchellad's Avatar
02 C320 S.E., 02 BMW 330XI, 00 4Runner
I've traced the antenna from the telaid system, and yes, there is an antenna in the rear bumper as well. I had the bumper off the car for painting, and the wire runs from the consol all the way back to the rear bumper, and winds back and forth inside the bumper molding.
Old Nov 11, 2002 | 08:13 PM
E320's Avatar
getchellad,
Do you mean inside the rear bumper?What does it look like?squarish thing?
Old Nov 11, 2002 | 09:47 PM
Lynn's Avatar
The one and only GPS antenna is the stub antenna on the rear glass. Tele-Aid has two analog cellular phone antennae, one of which is in the rear bumper.
Old Nov 11, 2002 | 11:07 PM
getchellad's Avatar
E320,
The inside of the plastic bumper cover, is essentailly stierfoam, and it has an area for the wire to snake back and forth through the bumper. From what I could tell, it doesn't connect to anything in the bumper. I didn't look to closely, but it appeared to be just set in there. I guess just by snaking back and forth, it can get the reception that's needed.
Know if someone else could answere this question. Is this related at all to the radio reception? Are the two systems in any way interconnected?
Old Nov 13, 2002 | 03:35 PM
BrabusPower's Avatar
Isn't the antenna on the rear center glass for absorting thunders?
Old Nov 13, 2002 | 04:11 PM
Tai230K's Avatar
2011 E550 Sedan
Post
Yep SURE IS!!... once in a while i turn on my flux capacitor to use lightning to power that sucker.... when i'm out of plutonium
Old Nov 13, 2002 | 08:23 PM
oggle's Avatar
E320
If I buy a Command and want to retrofit it onto my 2003 C320, do I have to install another antenna on my car or will I be able to use the existing antenna?
Old Nov 13, 2002 | 08:27 PM
Lynn's Avatar
I don't know, oggle. I have heard that question answered both ways.
Old Nov 19, 2002 | 01:47 PM
LOL
Old May 7, 2008 | 02:03 AM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Sorry to bring back this old thread. I have two antennas on my car already as seen in the picture, and I thought one of them should be the GPS antenna, so I didn't order them with my euro command. When my dealer installed my command they told me I don't have the GPS antenna and I won't be able to use it so I didn't even bother to find out the truth. Now that I know the DVD can be cracked, I want to know if I still need the GPS command. If so what kind? I looked on eBay and there are Panasonic and Alpine who both make W203 GPS antenna. Which one do you think is better? Thanks.
Old May 7, 2008 | 09:53 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
WhenI retrofitted the COMAND into my car, I purchased the GPS antenna.
It is installed just about under the center speaker grill on the dash, kinda tucked in snug.
If you buy the MB Maintenance DVD, it will show step-by-step on how to retrofit the antenna and COMAND unit.
The retrofit instructions give you the part number for the GPS antenna that you need.
The pointy antenna on the rear glass is for the cell phone, as most cars came with telephone prewiring. I have the telehphone and it charges through the system and uses the external antenna, resulting in a better signal.
The GPS is installed somewhere near the rear roofline somewhere if I remember right (only with teleaid or factory installed COMAND).
Old May 7, 2008 | 01:13 PM
acr2001's Avatar
2012 C300 4Matic
Finally someone in this thread who knows what they're talking about!
(No offense guys)
The little stub antenna on the glass is for teleaid / cellular - NOT GPS.
The antenna in the bumper is a backup teleaid antenna incase the car rolls in an accident - NOT GPS.
If you have a W203 with stock COMAND the gps antenna is mounted inside the car at the very top of the rear window inside the edge of the headliner where it cannot be seen from inside or outside (under the black area of the glass.)
Old May 8, 2008 | 02:17 AM
capt_paul's Avatar
It helps to have the MB Maintenance DVD. I learned sooo much about all the systems of the car in the information part of the DVD. I have saved hundreds, if not thousands, by doing stuff myself with the help of the DVD.
Old May 14, 2008 | 12:18 AM
waltleex4's Avatar
2002 c240
GPS ANT
can I use the GPS conection from my factory unit for the AVIC D-3
