Help With Wheel/Suspension Setup ?
Old Nov 13, 2002 | 11:56 AM
c200k uk's Avatar
Hi,
i'm new here, first of all i'd like to say i'm in the UK and i have a w203 c-200 kompressor saloon which is not too bad even though i'v had loads of probs with it (mainly trip computer probs and stupid dealer)
Any as my model is a classic (manual too) i would like 2 know what wheels would fit the car and which/where/how much for suspension lowering springs ?
I was thinking of 17's with a 30mm-40mm drop, would that be any good ?
Also while i'm here i would like to ask wheather it is possible to replace or upgrade the tiny sub it comes with as standard in the boot ?
Any advice would be great !
thanks
Old Nov 13, 2002 | 12:24 PM
dr_feelgood's Avatar
Like Crazy
Re: Help With Wheel/Suspension Setup ?
thanks [/B][/QUOTE]
somehow the same thought crossed my mind. after doing some research on the market on whether or not free-air subs are still popular, i only found a kicker 8 inch midbass. it would hit harder though but going through all the trouble like changing the amp and re-mounting the sub, i suggest that you should just disable the rear deck sub and add an enclosed sub in the boot.
Old Nov 13, 2002 | 12:28 PM
Harris's Avatar
Re: Re: Help With Wheel/Suspension Setup ?
somehow the same thought crossed my mind. after doing some research on the market on whether or not free-air subs are still popular, i only found a kicker 8 inch midbass. it would hit harder though but going through all the trouble like changing the amp and re-mounting the sub, i suggest that you should just disable the rear deck sub and add an enclosed sub in the boot. [/B]
Totally agree!!
Old Nov 13, 2002 | 12:34 PM
Harris's Avatar
Originally posted by c200k uk
Hi,
thanks
There are a lot of wheels that can be fitted on a W203 sedan. I think the first question you have to ask yourself is how much are you willing to spend and what kind of wheels do you like (classic 5 spokes, multi-spokes or mesh). Maybe you should check it out at various websites such as Tirerack, Brabus, Carlsson, Renntech etc and get an idea of what you like.
As far as suspension goes, 30-40mm drop is only 1.2"-1.6, which isnt that much, H&R might be too low for you. Maybe you can try Renntech springs, they are really good.
Hope this helps.
c200k uk's Avatar
so with regard to my queery on wheels and suspension could someone please please help me as i'm new to this kinda stuff?
thanks
Old Nov 13, 2002 | 12:37 PM
c200k uk's Avatar
sorry just read your post !
ok well i like a set of wheels u get over here in the uk (dont think u can get them in the usa) any way they are 17" 205/40/17, would they fit alright with 30-40mm drop or even more? considering i carry people in the back and sometimes fill my boot up, i wouldnt want to have them scraping the arches?
thanks
Old Nov 13, 2002 | 12:45 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
thanks
Start your search with Google search . Type in perfomance wheels or the above mentioned aftermarket tuners listed. Because you obviously have enough experience on the web to find this website, I'm confident you'll do just fine on your search. Most guys/gals on the list will be more than happy to assist or provide opinions...after we feel you've done a wee bit more research. btw, please note this list does have a search feature too. Check it out too.
Old Nov 13, 2002 | 12:52 PM
Harris's Avatar
thanks
do u have a pic of the wheel to show us?
btw, I've replied to yr e-mail.
Old Nov 13, 2002 | 01:08 PM
c200k uk's Avatar
go to this link : http://www.tyresave.co.uk/alloykhn.html
and go down to the kahn rs-s and kahn rs-c ! these are the two i'm considering! what do u think of them ?
Old Nov 13, 2002 | 01:23 PM
Harris's Avatar
IMO, there's nothing special about the RS-S, it looks like one of the 17" factory VW Bora wheel. The RS-C looks nicer, but I am not a fan of 'lip-less" wheels. Just my opinion!!
Old Nov 14, 2002 | 05:57 AM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
I think 205/40/17 is too "skinny" for C class, and the overall diameter of the tyres would be less than the stock tyres...that means your speedo might not be accurate if you put 205/40/17 tyres.
225/45/17 on 17x7.5" wheels would be a better choice, you won't have any problems about the tyres scraping the wheel arches. As for springs, there are a few out there... H&R, Eibach, Kleemann, etc...
I've got Eibach on my car (C200K too) and the springs lowered my car for about 30mm, and the rides are quite comfortable too.
Old Nov 14, 2002 | 07:16 AM
W0n6_3d4n's Avatar
C200K (w204)
Totally agree with bajaiman.
Regarding the subs try Hertz air series design for free air, made in italy and it is quite expensive though, $600+ for 12 inch.
