my return
Old Dec 25, 2007 | 07:53 PM
dragonskin's Avatar
2007 C230 sport
my return
In May I return to the states after leaving my C230 sitting in a garage for 7 months. Is there any steps to take before I drive on an extended drive, it is an 07?
Old Dec 25, 2007 | 07:59 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
not sure but i would def change the oil and check the tires (pressure and flat spots)
Old Dec 26, 2007 | 12:22 AM
Buellwinkle's Avatar
Gasoline gets oxidized from the oxygenate additives used in modern fuel. What it does is coats the injectors and fuel lines with a varnish. Hopefully you knew you were leaving for a long time and added a fuel stabilizer like Sta-Bil. If not, after a few tankfuls using some injector cleaner it should go back to normal. I know my motorcycle gets like that if I don't drive it for 2 months or so.
Modern low profile tires do develop flat spots, can be annoying. I heard people put hight pressure, like 60 lbs for a day or so to round out the tires, otherwise they may thump for a while.
The battery charge may be low. Would be a good idea to put a charger on it for overnight or if it starts, drive it for at least an hour to let it charge.
