Avic D3 installed now SRS light ON C240
2001 C320
I have a N3 installed in my 01 C320, and my SRS light came on one day. I have had the N3 installed for over a year now, and one day when i went out for lunch, the SRS airbag message suddenly appeared. Do you guys think that I have a bad sensor, or is it the wire you guys are talking about thats causing the problem? I wasn't bumpin or anything that would cause the wire to fall out place.
2003 C230K SS
Damn! I have been looking for one of those, hopefully he has 2!
hey guys, the CA-R-PI.131 has 3 conectors one of them is called "ISO POWER" with 3 wires coming out (yellow red and brown) i was having problems figuering where to plug this into... soo leaving it unplugged i went and turned the unit on... to find out that the steering controls worked with only the 2 connectors pluged in.
and the cluster says "PIONEER".
am i missing something here? the ISO power plug comming from the CA-R-PI.131 is left alone?
2001 C240 6spd
2001 C240 6spd
2001 C240 B/B 6spd
Not sure if anyone found the solution to the SRS light problem after installing a radio but I have had the same problem for a long time and even after the light was reset, I still have the same issue. I'll check my connections but has anyone come up with another solution to this?
Not to add more problems but I have the eclipse AVN installed with the parrot Bluetooth and I can hear my callers just fine but they cannot hear me for some reason. They say I come in broken with lots of static. I have since moved my mic to the instrument cluster and same thing happens. When the engine is off they say it sounds a lot better. I originally had the Motorola crazor and have since changed to the rizor. Any solution to these issues? Sorry for high jacking this post.
