general views on manny box?
Mines the classic, with 15" steels and fake wooden trim on dash oh and also the crappy fake "mb lex" synthetic leather. do u get that in the states ?
is it possible to upgrade the fake wooden trim to the aluminium one that comes with the avantgarde package? also is there no short shift kit available for the manuals?
I also feel its totaly impossible to shift fast on the mannual cause the gaiters are just so far away !
I believe you can change out the interior trim - from the wood to the CF/aluminum.
I believe the C230 Coupe has a shorter throw 6spd manual. I dont know how cost effective it would be to exchange it out. You can also probably check with Renntech or Brabus - they make manual trans and may offer a shorter throw shifter. But, again, i think the cost would be greater than the benefit. Unless you have an unlimited supply of cash - Euro's and/or Pounds.
http://www.zvolution.com/c230k/C7Shifter.htm
jlm
I've also driven the C7 Hatchback and thought its manny transmission was also excellent.
The only thing I would change on both is making 1st gear (and maybe second) a little higher.
Cheers, BT
I wouldn't raise the ratios. Those "granny" gears are great for slow moving traffic (along with the low end torque). Saves riding the clutch. I do wish 6th was a bit higher though (or at least further away from 5th).
I like the manny too. Yes it's sometimes hard to get into first when moving...
Cheers, BT
I like the manny too. Yes it's sometimes hard to get into first when moving, but 2nd is so low and the 2.3 so torquey that you can start in 2nd from a very slow crawl. I don't bother with 1st unless I'm stopped anyway. So what's the problem?
On the C240 I wouldn't change em, the car is too underpowered as it is thru the first three gears.
And yes, the C7 shifter makes a world of difference...the throws are too long on the stock shifter. Otherwise its a nice gearbox.
For those of you who might want an improvement over the C7, UUC should be finalizing their short shift kit before Turkey Day (and hopefully will have a billet shift knob as well), and I should have pics/report of how well it works about then. Stay tuned!
The 5-spd in my 325 has ideal ratios and far better shift feel, but the clutch is an unforgiving monster and I sometimes wish for a 6th (5th is direct drive, so at 70 MPH it's turning around 3,300 RPM).
The C240/C320 sedans have MB-Tex bolsters w/ leather center inserts standard. Full leather option adds leather bolsters, headrests, side door inserts and nicer (i.e., "French seam") stitching.
I saw both the standard and full leather interiors before I ordered my car -- you would be very hard pressed to notice or feel the difference. The visible clues are the double-row stitching and "gathers" on the door insert trim.
Actually I think the gates are pretty close together, compared w/ my previous '99 Passat.
I find the 6 speed in our C240 to be excellent. Very smooth shifting, light but solid action, no problems at all.
Also overhere they rate the new A4, 3 series and is200 much better than the c200k sedan, why is this? bmw's are sooo common over here !
I'm not a huge fan of the manny (but anything's better than an auto).
I didn't know MB had fake wood trim -- my C240 has real wood trim -- are you sure it's fake?
I agree -- I'd like to drive an example of one of the "problem" tranny's. Also, I'm wondering if the short throw linkage is standard on the C240 because I don't find the throws long.
also when i test drove the 02 it was a non C7. when i test drove a 03 it was was equipped with C7. though the test drives were 4 months apart i didnt notice a difference in the manny's from non C7 and C7. probably because of the time frame. the auto was never an option for me so i never test drove one. i just prefer a manual transmission!
Tommy, make sure you let us know when the new shifter is done! I have a non-C7 shifter and it is terrible. Sloppy, vague, and still has that nasty 1st to 2nd shift. Hopefully, the UUC shifter will fix some of these problems.
