Heating issue
You might have broken linkage on the stepper motors that move the air control flaps in the dash. The part is cheap, but it takes all darn day to take the dash apart to fix it.
Heaters in FL often die of boredom, and lack of use with high summer heat contributes to the broken linkages.
I don't think you are doing anything wrong. You might try pushing the recirculate button to see if the outside air door will close. This might allow the center vent to warm up a bit. When you hit the windshield defrost button, do the dash vents close and the window vents open and blow dragon breath on the inside the glass?
