How to attach a spoiler on glass
I have a particular one in mind. It's the Renntech roof spoiler. There's a very minimal surface area to mount, so I don't think 3m tape would work. The only areas touching the car is the perimeter. 1/8" all around.
My intention is for the spoiler to be mounted permanently.
I hear silicone gets messy. Is there an alternative method of application of the roof spoiler?
Any and all comments are welcome.
might not fall off, but could easily get ripped off by someone or a car wash haha
i think your only shot is some liquid based substance
I agree that 3M alone will not do the job. You take 3 M tape and make a thin line around the whole surface of the spoiler so that you have in the middle a lot of space left. Then you go to any body shop and ask for windshield glue. It's not silicon, it's much more thicker and stronger. You put that on the spoilers surface which would be inside the double sided tape area. Then you peel off the double sided tape and mount it on the glass.
Clean the glass surface first though.
I have installed it like this on the following cars:
99 Passat, 01 525i, 03 Acura TL, 05 Benz Coupe, 98 C class.
All of them worked perfectly and you literally won't be able to take it off even if you really try it
Gorilla Glue...hmmmm.
SLAMMER111: i heard that the silicone is just too messy especially for glass. Remember the spoiler can be seen from the inside. The underside of the spoiler therefore has to be really clean to be acceptable.
ADVANS: You've got a sweet ride, but your spoilers have much more surface area to mount 3m tape onto. I don't think i'm lucky enough with the Renntech spoiler.
Can you guys tell me more about that windshield glue?
As for the strength of the glue... how long do you plan on keeping the spoiler/car? One big thing for me is removeability, even if it's 10 years down the road.
http://www.uline.com/ProductDetail.a...-9796&ref=6001
Has anyone else tried/used it?
Wow! Thank you so much for the link! Much appreciated!
The problem is that unlike a spoiler on a trunk, the spoiler on the glass exposes itself to inside occupants and me when I look back at the rear windshield. The sedans have a groove of weatherstripping that's black and that's the attachment point for the spoiler, but there's no 10-15 cm area to paste it onto unfortunately.
Removability isn't as much of a concern for me. I'm sure I'll like having it on there.
So it would be Glass -> Mounting point -> Spoiler
Rather than having the spoiler attached directly to the glass?
