LED Interior lighting
i personally have the 4 piece blue interior kit from http://www.ledunderbody.com
i also have their underbody blue led kit
i really would recommend buying the led's from them
other interior lighting products i have seen are cheaply made
and not nearly as bright. the ones i have contain 18 leds per tube
so its definitely very bright
mine are powered from the fuse box directly behind ur headlamp controls
2 of my tubes are located directly above the driver and pass. footwell
and the other 2 are underneath the front seats aimed forward.
. hmmmmm.WARNING:
Be very careful about using LED's under the car vs using normal neons. Since our cars are a bit low to the ground the LED's will show up as dots on the ground rather than a clean blend that you would get with neons. for under body, i'd recommend neons over LED's for this reason.
