nitrous kit in C230k coupe. has anyone done it? how many shots?wet or dry?Thanks.
2002 C230 Coupe Black/Charcoal C5 C7 Auto
Curious how many here has nos kit in the c230k engine. I'm concern with whether the engine can hold up about 35-50 shots. Also I'm concern how good MB dealers are at detecting the presence of a nos kit (I know a shop that can put in a kit very discretely). All my planned mods are "bolt-on" except for this nos kit and i know my car is on lease but figure I can have fun for about 3 yrs until lease is up (then take apart everything and sell back....i can seal where the nos kit has been as well and put covers back on, etc). I am planning to do pulley and chip first so figure another 35-50hp couldnt hurt. :p
*Your UNBIASED opinion/input/feedback/suggestion is appreciated.
Location: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
1 Post
C230 Sports Coupe
i think it could handle a 35-50 shot. You will IMO need a new intercooler and ecu i think.
I think if you do NOS on a stock car its ok. But with as pullied car you might be pushing it a little hard. But thats just speculation
Originally posted by lhoang
tberry - u cwazy!
anyways, you get those spacer on yet, and how much did u pay for those bolts?
NOS, gee wiz, wally.
tberry - u cwazy!
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
*So howz your set of wheels going? what r u on 8th? 9th set?
1 Post
2002 C230 Coupe(M111)
Youre asking for trouble with nos on a forced induction car, unless its a port injection setup with a standalone computer...but youre going to do this anyway so.....
Never use a dry kit. They should call these things "kaboom" kits. Often the stock injectors do not have the capacity or fuel pressure to pump enough fuel to keep up with the NOS. Especially if your running a pulley. The pulley makes more boost...more boost needs more fuel, or Kaboom, you get detonation. Be mindful of your fuel and octane settings...one of them, IIRC will limit the engines ability to "pull back" the timing in the interests of using high octane fuel. Should detonation set in, this could be very dangerous. Given how lean they run with a pulley, I'd go for stage 3 on the fuel and build in a little insurance that while you're spraying at 5500RPM full throttle, she doesn't go lean on you. You'll loose a little of the HP the pulley would normally give you...but that's better than a hole in the top of your piston. I'd be nervous with running more than a 50 or 75 shot, given that this car is already pressurized. I'd stick the money that a NOS kit is going to cost you towards a new intercooler. More boost is what's going to make this car fly reliably.
Nope, the stock intercooler is fine for NOS. NOS doesn't need ANY intercooler. The stuff is sprayed after the intercooler anyway, and by its very nature its quite cold. You might find that a 50 shot gives you a '60' effect due to the extra cooling you get.
As long as you have enough fuel, you'll be fine. I used to run nitrous on my Saturn Coupe. A fifty shot was enough to go out gunning for Integra Type R's and any Beemer shy of the M3, and a 75 shot made guys in muscle cars nervous. Get a good kit...if you have a failure and the ******* stops spraying fuel, you'll have a nightmare. I'd get a button AND a window switch(use the window to limit when the button can be activated), you'll use a lot less NOS(it gets expensive after awhile)
Good luck, and let use know when you blow the motor!
1 Post
Originally posted by tberry
Well you make a lot of sense and i'm definitely 2nd guessing my decision. I had a friend who had audi 1.8t motor and had 75-100shot on stock motor it it was fine (for years). I figure the MB 2.3L engines can handle that much. How about just a 35shot wet kit with fuel setting stage 2-3? I'll defintely get full kit with bottle warmers, valve open/close switch, and 'window' switch. if figure on top of ECU+pulley the other mods get VERY expensive (if any) and not really worth the money to hp ratio PLUS they're not quite "bolt on" anymore. If you have any other bolt on good performance mods after pulley+chip please let me know. thanks.
The VeeDub's(Audi 1.8s are the same motor) can turn out copious amounts of HP just by turning up the boost, why waste money on the NOS? And being they are turbocharged, they don't have to pay the parasite(turning the supercharger with engine power), meaning more of boost goes to developing useable wheel HP, not just turning over the compressor. Using NOS to spool up a large turbo works good, but as a "bolt on" mod, its a lot of work for what can be a very problematic 'lifestyle accessory'.
Get the pulley first. See how you like that.
also Nos gives you 35-50hp at wheel not crank (i assume the pulley+chip if i'm luck will get about 25-30hp at wheel on dyno).
Audi S4
At some point I think you need to think about the stress this is putting on the drivetrain. At what point does the stress become too much for the tranny and diff? I'm sure one of our resident experts here could give you some real information, but it would seem to me that having 300 hp going through a driveline designed for 192 may be pushing it a little.
BTW tberry didnt you mention you got the 230 because you were spending too much on mods? Doesnt seem like its working
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
*Yeah does anyone know how much can the auto tranny in C230k handle hp/torque wise? i know the audi tiptronic was about 250-260hp/lb/ft.
2002 C230 K
Cheers, BT
Former Vendor of MBWorld
Originally posted by trench
I'm pretty sure that AMG doesn't upgrade the transmission internals for the C32 from the standard slush box present in the C class line-up. Therefore the stock tranny should be able to handle at least the same amount of hp and torque as a C32 (and probably more).
Cheers, BT
Cheers, BT
I recall reading in the November issue of "Mercedes Enthusiast" something about the software limits that AMG was putting on some diesel engines. They allowed 330 ft-lbs with the auto, and 310 with the manual. ( I was just idly browsing, so don't trust my memory on the exact figures. ) The Dec issue is not out yet so you might still be able to pick up a Nov issue if you move quickly.
1 Post
Originally posted by Robert Schrader
Sorry to quibble, but it's excess torque not hp that hurts drivetrains.
At any rate, the tranny is the least of your worries. I remember the same argurments against boosting my Saturn. The tranny won't handle it...yada yada yada. With the bolt ons, exhaust and Nitrous, the car was probably putting down 230HP thru the stock driveline when under 75 shot. Nothing ever broke. The clutch did start to slip, but that was the result of years of city commuting. Disc and Plate were fine...fingers wore out. If the power gets so out of control(ha!) the clutch will likely slip first. Even if it doesn't, replacing a tranny is a whole lot less work in a RWD car
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
P.S. Can I have your very cool Climatronic unit if you blow up your engine?
2002 C230 K
I was under the impression that AMG did tranny upgrades, but maybe that was only on some of the older (W202 C43, W210 E55) AMGs.
Cheers, BT
