Need Help! HID issue
Old Feb 15, 2008 | 02:34 PM
advans's Avatar
C55 ///AMG, 535xi
Hi All,
I've been trying to solve this, and its a pain...a serious pain in the a-ss. The issue is for drivers side...fog light
this is a HID FOG light issue. Everything has been working fine with my HID fogs since I got them, until my ballast gave in. I replaced it for a new slim ballast from the same manufacturer. The fogs worked, it worked great. Then my fog light bulb burned out. I replaced the bulbs. it didn't work. I replaced the resistor, it worked! Then after a month or so of use, it shut down on me again. as of now, the Ballast+Ignitor, Resistor, Bulb are all brand new. I have no clue whats going on.
I did a few tests.
I plugged in a few sets of bulbs, none of em worked. If it was a resistor problem, the bulbs would still flicker once in a while, but it didn't.
I plugged in a standard 9006 bulb, and it works!
any clue what might be going on? might be another faulty ballast/ignitor?
Old Feb 15, 2008 | 03:03 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
I will start by saying my HID knowledge is really small. But, my electrical knowledge is pretty darn good. Since I doubt you bought a cheap kit, I find it a little suspect that you are having that many faulty components with a quality system. With that said, I suspect possibly a bad ground based on your issues.
Old Feb 15, 2008 | 04:20 PM
cyanide's Avatar
'07 Mercedes C200 CDI Sportcoupe
Try to connect it directly to the battery and see if it works.. Maybe you have to make a new circuit with a relay. Or a new ground wire as johnand suggests..
Old Feb 15, 2008 | 04:22 PM
infected's Avatar
2007 ML500
Can you try the ballasts and ignitors on a different vehicle to see?
Old Feb 15, 2008 | 06:27 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
try it on your other benz and see are the HID having problem or your car??
Old Feb 15, 2008 | 08:53 PM
advans's Avatar
C55 ///AMG, 535xi
your right guys, I think on a warmer day, ima swap it to the passanger side, and see whats going on, if it is fully functional, I'm assuming its a bad resistor (i just replaced it!).
I can't put non stock fog bulbs on the ML, even if i put luminics in there, the fuse blows. and the E, lol I am afraid to take apart.
But I guess I'ma swap left and right next week, when its a bit warmer.
thanks!
