How many caliper pistons?
Old Feb 18, 2008 | 05:20 PM
RBONNE's Avatar
2005 C230 Kompressor
Have a '05 C230 Kompressor with the "Sport Package" and have the Brake service light on. I'm going to order pads for the front but not sure if I have the 4 piston calipers or the 2, does anyone know?
Old Feb 18, 2008 | 06:59 PM
WaveyKat's Avatar
Something Slow
4
Old Feb 18, 2008 | 09:25 PM
bumpnzx3's Avatar
W203 C230SS
i used to think the same thing, but i was proven wrong by "e1000"
i believe the only non amg W203's that have the 4 piston fronts is the 2004.5 cars. the 2005-2007 have 2 pistons.
Old Feb 18, 2008 | 09:31 PM
bumpnzx3's Avatar
W203 C230SS
https://mbworld.org/forums/showthread.php?t=231041
there ya go- a senior member confirmed.
Old Feb 18, 2008 | 10:01 PM
e1000's Avatar
a quarter mile at a time
ok.
2004.5 has the 4 piston calipers.
only SOME early 2005's have the 4 piston calipers
after that, 2005+ cars have 2 piston calipers.
C350's have the 4-piston calipers.
easy way to tell is to look at the caliper, if it had 2 torx bolts on the outside, one on each side of the caliper, it's 2 piston, if you have 4 bolts visible, it's 4-piston.
Old Feb 18, 2008 | 10:03 PM
e1000's Avatar
and it's "How many piston calipers"
Old Feb 18, 2008 | 10:24 PM
06c230hwd's Avatar
06' C230SS
Originally Posted by e1000
ok.
easy way to tell is to look at the caliper, if it had 2 hex bolts on the outside, one on each side of the caliper, it's 2 piston, if you have 4 bolts visible, it's 4-piston.
jsut get out there and look!
Old Feb 19, 2008 | 07:12 AM
RBONNE's Avatar
I have 2 torx bolts on the calipers so 2 piston it is. Thanks guys
Old Feb 19, 2008 | 10:15 AM
bondock's Avatar
Alright noob question!
What would the difference be to the driver between a 2 piston caliper and a 4 piston caliper?
Thanks.
Old Feb 19, 2008 | 11:20 AM
e1000's Avatar
Thanks.
Cost. Although I've driven both and honestly, there's not a huge difference. Even the two piston fixed calipers are more than adequate to stop the C230.
Old Feb 19, 2008 | 07:53 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
4 cuatro
