andy_meng1024's 4MATIC Lowered W203 thread
Anyway, if you can find a good shop to wrap it in CF, why not? Lorinser CF trunk lip is very very rare
Do you use any hubcentric rings on those MRRs?
2003 SL55, 2010 C63
Yeah I like the carbon fiber wrap but don't know where to find a shop to do it. I don't think I am using hubcentric rings on the new wheels. In fact, I just looked into it right now and still don't know what does it do. Is it like a spacer?
You're running staggered set-up on your 4matic
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
maybe someone can run his license plate for you
and find out where the ******* lives
i dug up this picture of his car from a meet last april
license plate # 98SM64
![](https://mbworld.org/forums/attachments/c-class-w203/103556d1177305026-boston-w203-meet-april-16-22-031.jpg)
#32
2005 A4 1.8TQ
Hey Kev...
![](http://johnbatchelorshow.com/admin/allsource/exampleimages/stop%20snitching.jpg)
Just kidding, I'd be pissed if someone stole enough money from me to buy new wheels.
Your car is looking tight Andy. Nice to see the E63 front on someone's car that isn't silver.
#33
2003 SL55, 2010 C63
I don't remember what offsets for the wheels but they fit just fine. I've been running staggered setup for two years since I got the car and it's been fine. But I also got the 275/30/19 rear tires to make the total diameter only 0.1% different from the front tires though.
#38
2003 SL55, 2010 C63
I took my car in yesterday for alignment as the car keep leans to the right after the install. Today my dealer told me that they found out one of the front spring was installed up side down and they need another day or two to fix it.
Has this happened to any of you before? Could this have damaged my car?
#39
Car looks great...my rim deal fell through, so now these MRR's are at the top of my rim choice....but looking at your car, I have two questions:
1) will the 275 rear fit on my '05 C230 SS with that same offest (i'm assuming you have the et35 rear) w/o rubbing?
2) can the rim be kicked a bit more to the edge via a spacer with the 275 or would you need the 265? It just deosn't look as aggressive as some of the other rim pics i've seen.
#40
2003 SL55, 2010 C63
2) Yes, you can use spacers to make it look more aggressive.
#41
1) It would fit but then you can't lower your car much or it'd rub. 265 is usually the largest size people would go for W203. I put 275 because on 4Matic I need the overall diameter to be the same with front. I think 265 would be a better choice for you.
#42
How much of a drop did you get? 30mm? I'm looking at a 30mm from some Brabus 4matic springs. Also, how did the front springs get fixed up? Did you need a cup to hold the front springs on the bottom?
#44
2003 SL55, 2010 C63
I don't know how much exactly but the gap was about 4 fingers and now it's about 1 1/2 to 2 fingers with no one in the car in the front. Back was 3 fingers and now it's 1 finger gap. I think on the websites it says 35 mm drop tho.
