2004 C230K Question...
I recently bought an 04 c230K Coupe. I am wondering if i have the bose sound option? I have the two sunroofs.. not sure if that helps any. And in the trunk on the left side in that little hide away there are about 3-4 wires end's with connectors on them. What are those for? One says.. TEL The other one says TEL 4 there's a big one that looks like a longer version of the vga cord that comes from your computer to hook into the back of your monitor. It's black and about twice as long, same height. And the other one looks like a coax i put in the back of my tv for cable... What the heck are all these for? Thanks.
Turn the key to the "on" position.
Turn your stereo off, then turn it back on...
Lower the volume all the way down. Turn the radio to 88.1 FM.
Then, put your bass all the way up.
Using your steering wheel control, raise the volume three times. (Press the "up" button 3 times)
Then, open the trunk, and remove the cover off of where the spare tire is. If you see a Hologram of Doogie Howser, then you definetely have the Bose stereo...
If you haven't done so, click on Doogie Howser
