factory radio removal.. any tools needed.
2007 SL550 Roadster
Do you mean "02 c230 stock tape deck"?
Anyway, the W203 C-Class factory radios are not removed via special "keys." The radio is bolted in (with four bolts). To get to these bolts, you must disassemble the console (remove the air vents and the cover surrounding the radio). This procedure is documented, on a web page that I created.
http://www.stormpages.com/arialis/mb/changer/index.html
I hope that this helps. There has been plenty o' discussion about this, on this forum, so most of the information should be available in other threads.
-Pete
-Pete
