factory amp missing NEED HELP!!!
Old Mar 11, 2008 | 06:55 PM
2k5C230's Avatar
I have a huge problem and I am hoping you guys can help me out. I had an aftermarket navi installed and today the place that installed it went to reinstall my factory system because my lease is up tomorrow.
Now the fun part. The stereo shop tells me the factory amp is missing. Long story short I am screwed.
First question. Where is the factory amp supposed to be located? The car is a 2005 c230 and I have the upgraded entertainment package.
Second question. What would be the cost to replace the amp?
Any help would be much appreciated. Thanks in advance.
Old Mar 11, 2008 | 07:42 PM
r0mantics0ul's Avatar
2005 c230k ss
the amp in on the right side of the trunk. take the cover off then you will see a maybe 10in by 8in amp. sorry dont know how much is it to replace tho
Old Mar 11, 2008 | 07:55 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
How did it wind up missing? Did you check what they did when you installed the aftermarket stuff?
No flame, but that's why its a bad idea to mod when you're renting.
Old Mar 11, 2008 | 08:13 PM
Moviela's Avatar
The factory amp weighs 4 lbs and costs about $ 300.00 per pound. If it is not in the trunk on the rear of the wheel arch (passenger side), and there is no connector for the speakers in the rear, you did not have an amp.
The head unit is the same for premium sound amp or not. There is a power amp in the head unit. If the speaker wires are on connectors for the HU, you did not have an amp for premium sound. The installer should be able to run wires to the head unit for the speakers.
Do you have a subwoofer? It would be under the package shelf. If it is not there, you did not have premium sound.
Lastly, if you did have premium sound, and you connect the speakers to the head unit directly, there is no place to attach a subwoofer. You will also need to connect the dealers computer to program the head unit to run without an external amp.
Old Mar 11, 2008 | 10:26 PM
2k5C230's Avatar
No i didn't check when they installed the aftermarket stuff. I figured they just left it in there. I looked in the box they gave me and only the head unit was in there. And yes I am learning not to mod my leases so much.
Old Mar 11, 2008 | 10:27 PM
2k5C230's Avatar
Thanks for all your help so far guys. Can someone just give me a more detailed description as to where the amp is located. I understand it is supposed to be in the trunk on the passenger side, but do I have to remove the carpeting to see it or what? Can someone maybe take a picture for me. Thanks again!
Old Mar 12, 2008 | 01:30 AM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
This is how it looks like. I took off the carpeting along time ago when I tried to figure out the bluetooth stuff for the phone.
Old Mar 12, 2008 | 08:56 AM
2k5C230's Avatar
Thanks a lot for the pic. Mine is definitely missing. All the wires are hanging. This sucks.
Old Mar 12, 2008 | 11:27 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Had to have been the shop that did the install.
The original paperwork with the car comes with a small sheel with a list of option codes, one would be the amp, though I think only the dealer can decipher those codes.
Also on EPC it tells you.
