Aftermarket handbrake
Has anyone seen a Sport Coupe with a hand operated emergency/parking brake?
I suspect that mechanically it would be fairly simple to do, but making it look good would be difficult.
Any ideas on this? Thanks.
I'm not a big fan of the foot-brake either, but it does clean up the look of the interior a lot. I just don't liek stepping on the footbrake, just doesn't seem right.
Originally posted by dswildfire
well it'd be nice to have the handbrake in the appropriate position, but i dont think there's enough space
2002 C230K
really? 95% of owners don't use them? well i guess it makes sense because of the automatics, but still, would be nice option for those who do use them, like to use them, or may use them for "creative driving."
'00 ML320 Elegance/'03 C320 4-matic
Originally posted by MacPhisto
Why don't you just put the car in "Park" and forget about the footbrake?
Originally posted by Drew_ML
It is not a good idea to use Park only. Park simply sticks the parking pawl into one of the cogs in the gear. Without using the parking brake, the pawl obviously has to deal with a lot more stress, especially if there is a slope. Always apply your parking brake.
You are correct, there is a pawl that goes into a "gear" (it is actually a splined shaft) to hold a car stationary on an automatic transmission car. However, the pawl and splined shaft serve only one purpose: To prevent the car from moving when it is in park. The pawl and gear do nothing to make the car go.
So, if parking without the handbrake caused a failure, it would be a failure of the pawl and/or gear. The car would still drive, but when you put it in park, it would not be locked in place and could move (like it was in neutral). Has anyone EVER heard of that failure? Likely not. It would be highly unlikely, even if the parking brake was never used.
No one uses the parking brake in an automatic. Go to a dealership and look at all the automatics, none will have the parking brake on.
All that being said, sure, it can't hurt to use the parking brake. But, its a redundancy that is not really necessary. And, even if it was necessary, 95% of automatic drivers still wouldn't use it anyways. No biggie.
2002 C240 6-spd (ret)
I drive an auto, I too use my handbrake (or foot brake in this case) whenever I park. Just a habit. Contrary to your observation, I find lots of people I know use handbrakes. Not saying you're wrong, just saying my observation.
Originally posted by MarkL
Are you sure you're the "final" authority on the use of parking brakes? Of course, I always use it on my 6-spd C240, but I also always use it on my other car, an automatic, and a lot of other people I know use it too. I always set the brake first so the brakes take the brunt of the force of holding the car in place. Then I place the gear into "park". The fact that you've seen a lot of automatics on a car lot without the brake being set doesn't relate to anything about drivers "in the field". It could be one guy at the dealer who moves all the cars and is too lazy to set the brake. Just my $.02.
However, I'd be willing to bet that if you go to any parking lot in the U.S., and checked the parked automatics, 95% of them would not have the e-brake on.
Do you disagree?
(Of course, there is a very small minority like you, that uses a parking brake in an automatic.)
2010 C300 4matic
And even though I do take the easy way out, and trust me it is much easier with the number of cars to move (A lot of the time I'm halfway out the door coming to a stop and then putting into park), I don't consider this to be affecting the life of the transmission. If it did, I would probably set the brake, because someone has to own these cars someday and pay for repairs. I could be wrong, but this is one thing I don't lose sleep over.
2002 C230 Coupe Black/Charcoal C5 C7 Auto
I think it also depends on geographical location. I've had 5 automatic cars and I almost NEVER use the hand/foot break unless I'm parked at an incline (which is rare here in Houston, TX). If you live in San Francisco or something I can see why u'd use it often.
1 Post
2002 C230 Coupe(M111)
A large percentage of vehicles that have four wheel disc brakes depend on the parking brake to adjust the pads on the rear discs. I'm not entirely sure the MB system behaves the same way, but every other car with 4 wheel discs that we've owned has had it set up that way.
By not setting the parking brake, you may actually be letting your brakes go out of adjustment.
FWIW, I'd have prefered the centermounted parking brake lever like many of my other cars have had, if for no other reason than the great wintertime antics it provides. That said, I love the dual level storage compartment(heated, or airconditioned!), and adjustable armrest in the Benz...and when I forget to set the parking brake(on occasion) before I leave the car, its much easier to just stick my foot back in and push it down, than it would be to crawl back in the car to pull a lever. Each setup has its own advantages. A left side floor mounted handbrake would be nice too.
1 Post
2008 VW GTI
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
As I said in my first post, I'd say 95% of people with automatics don't use their parking brake.
Of course, in unusual hilly cities like San Francisco, that number may go up.
But, I still don't see anyone disagreeing with my point. Go to any parking lot (let's say, a large movie theater), and how many automatics do you think are going to have the parking brake on? I say 5% or less. Maybe 10%, being generous. Certainly, no one would believe that 20% are using the emergency brake. (Would you??). That's a bet you'd lose every time.
It doesn't surprise me that a lot of the automatic drivers here use it. "Enthusiast" drivers who can't drive a stick often do things that emulate stick shift drivers - which is why the silly "Tiptronic" gimmick slushboxes are so popular. Makes slushbox drivers believe they are driving the equivalent of a manual transmission, or have a transmission "Like a Formula 1 car."
Guest
Posts: n/a
The parking brake is over used in NA, and many of us manual drivers rarely leave our cars in gear and rely on the parking brake.
I actually prefer it on the floor, otherwise my MB wouldn't have very much storage room, as it is there isn't really enough for my liking, but I do admit that at first I stalled the car a few times forgetting to disengage the pakring brake, just wish the warning light was more visible, like the red door open screen, if I had a red "parking brake on" screen if I touched the gas that would be a nice feature.
2008 VW GTI
I prefer the parking brake on the floor. Something I only use 2 or 3 times a day should not be in the center console taking up space.
1 Post
