Brake Fluid Change Question
Old Apr 7, 2008 | 01:53 PM
ammar_rage's Avatar
C230 KOMPRESSOR (2003)
I was planning to get the brake fluid flush n fill, Its been over 2 yrs now. I dont wanna go to the dealership though so I know this local mechanic who is pretty good and he has all the documentation as to how to get the job done on these vehicles...I have a question that i wanted to ask before i go ahead with that guy,,,,What is the proper procedure to flush the brake fluid...i asked him and after checkin his system he said its just normal bleeding..
Any advise wud be apprecited
Old Apr 7, 2008 | 08:32 PM
coin's Avatar
'06 CLK500
Bleeding brake fluid should be a simple process, just make sure you use MB approved fluid or reputable aftermarket brands.
http://www.zeckhausen.com/bleeding_brakes.htm
OR
See step#13.
http://www.installuniversity.com/mb/.../amgbrake.html
Old Apr 8, 2008 | 08:35 AM
ammar_rage's Avatar
thanks Coin...definitely very handy! So bleeding brakes isnot really specilized process that you must go to the dealer for.....
Old Apr 8, 2008 | 01:27 PM
Tangerine's Avatar
Is @ Home
https://mbworld.org/forums/c-class-w203/224766-bleeding-brake-sequence.html
Old Apr 8, 2008 | 02:40 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
One of the many pdf's I made the other night, as I went through the entire service DVD.
No, surprisingly there's nothing fancy about how they do it!
You just need a pressure bleeder.
But you do need to get under the car and get access to all 4 bleed screws, which won't be fun in the driveway.
I'd pay $100 to not have to deal with it.
Just make sure they use compatible fluid...
our cars come "DOT +4" which is DOT 4 with a slightly higher boiling temp, and only sold at MB.
If you go to DOT5 you have to completely flush the whole system, and pray no one ever adds the wrong stuff by accident. Can't mix the 2.
File Type: pdf
Old Apr 8, 2008 | 03:15 PM
ammar_rage's Avatar
Thanks alot guys...much appreciated!
Old Apr 8, 2008 | 04:01 PM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
How much does MB dealers typically charge to replace brake fluid?
Old Apr 8, 2008 | 05:02 PM
C24owner's Avatar
'08 E550 4Matic
I was quoted about $150-$160 for a flush.
I did it myself this morning, took about an hour.
