View Poll Results: when you park (on a level surface) do you.....
leave it in gear (1st) w/out parking brake
7
16.28%
leave it in neutral w/ parking brake
7
16.28%
leave it in gear (1st) w/ parking brake
29
67.44%
Voters: 43. You may not vote on this poll
Old Dec 4, 2002 | 11:47 AM
truelove's Avatar
2003 MB C230 coupe
just wondering what everyone does
sorry, this is only for manual cars obviously.
Old Dec 4, 2002 | 12:12 PM
MacPhisto's Avatar
Its a good habit to leave it in gear and use the parking brake. A parking brake cable can fail, or you can not have the brake set fully. And, its possible to think you have it in gear, but it not really be in gear. Or it accidently pops out. Doing both is a good redundancy.
I usually leave it in first OR reverse, depending on how I am parked. If I am in a spot where I am going to use reverse to get out of the spot, I use reverse. If I am going to go forward when I leave, I use first. That way, if I accidently start the car in gear (no starter cutout), or my foot slips off the clutch, or the clutch MC goes out, etc., and the car lurches, it will at least lurch in the direction I am going, which should be clear.
Manual transmission cars are really about muscle memory and habit. Its a good habit to develop to use both the brake and the gears. After a while, you do it without even thinking about it, just like shifting.
Old Dec 4, 2002 | 12:15 PM
Buellwinkle's Avatar
Unlike the midwest, most streets by me (So Cal) have some sort of incline even if you can't tell. Also someone can bump you while parked (In NY people push you out of the way to make a parking spot). So I do both as a safety measure, habit, don't even think about it. If it's an incline I turn the wheels so the car would naturally go against the curb if all else failed.
Old Dec 4, 2002 | 01:36 PM
Lynn's Avatar
What? No one is using wheel chocks?
Old Dec 4, 2002 | 01:44 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
i set the brake and leave it gear. i also leave it gear in the direction i will be leaving once i return to the car, 1st or R, which ever applies for the specific situation.
Old Dec 4, 2002 | 01:50 PM
peet's Avatar
09 C63
I follow the saab mentality... reverse on flat, reverse and brake on incline.
BTW: if you didn't know, in a saab you can't take the key out without putting the tranny in R.
P
Old Dec 4, 2002 | 02:49 PM
MarkL's Avatar
2002 C240 6-spd (ret)
I also use the p-brake and leave it in gear. Here's a related comment: I don't mind the parking brake being a foot pedal except for one thing -- and after a year I've gotten used to it. When parking, I used to be able to leave the trans in 1st (clutch in, of course), hit the regular brake to stop, and set the parking brake by hand. Now I have to first shift to neutral so I can take my left foot of the regular brake to set the p-brake, then re-engage the clutch and go into 1st. A little more cumbersome...
Old Dec 4, 2002 | 03:06 PM
truelove's Avatar
2003 MB C230 coupe
here's what i do, it's pretty easy.
come to a stop with the clutch and brake pedal in (obviously). put it in gear, turn off car, release clutch and brake pedal, push in p-brake, get out.
Old Dec 4, 2002 | 03:25 PM
taylor192
Guest
Posts: n/a
I agree with MacPhisto, its all about habit. I drove my Camry like hell and developped a lot of bad habits, which I tried for a month to fix before picking up my C230K. If you do something constantly for 29 days (I think tht's the saying, but not sure) you'll develop a habit of doing it always.
As for me, brake, neutral, set parking brake, turn car off, put into reverse, get out. Opposite is, get in, neutral (you can tell if it is in reverse, shifter is in an ackward position to grip it), brake, start car, release parking brake, release brake and drive away.
I've got one question, is it better to leave it in reverse when parked on an incline, or in first? and vice versa when parked on a decline?
Old Dec 4, 2002 | 03:40 PM
MarkL's Avatar
That will work, but I prefer to have the p-brake take most of the effort of holding the car instead of the trans. So that's why I engage the p-brake first, release normal brake, re-clutch and engage 1st. Just a habit...
Old Dec 4, 2002 | 03:43 PM
truelove's Avatar
2003 MB C230 coupe
MarkL,
ah yes, i didn't even think of that. that is a good idea, especially on a hill. i will start doing that. i haven't formed any habits yet since i've only had the car since monday.
Old Dec 4, 2002 | 04:22 PM
MacPhisto's Avatar
On an incline, I would say that it's best to leave it in reverse, since reverse is the lowest gear ratio in the box, it has the highest "holding power." (if you were to try to push a car while in gear, it would be hardest to move the car while it was in reverse, then first, then second, etc.)
Then again, on an incline, you really should turn the wheels so that the curb holds the car in place as a last resort.
Old Dec 4, 2002 | 04:37 PM
Lynn's Avatar
In that case, use truelove's method, but press the parking brake with you left foot before releasing the brake with you right foot.
Old Dec 4, 2002 | 04:43 PM
20FHK02's Avatar
2002 C230 Coupe
That's what I always do: engage the parking brake before releasing the brake pedal.
Old Dec 4, 2002 | 04:47 PM
truelove's Avatar
2003 MB C230 coupe
actually, that's what i do too now that i think about it.
Old Dec 4, 2002 | 04:56 PM
MarkL's Avatar
I think that's what I originally said:
1. Come to a stop with normal brake, clutch in.
2. Go to neutral, still holding regular brake w/ right foot, let clutch out
3. Engage p-brake with left foot.
4. Release normal brake to let p-brake "hold"
5. Clutch in, gear in 1st (or reverse -- whatever)
6. Done!
Old Dec 4, 2002 | 08:14 PM
Matt230K's Avatar
2010 C300 4matic
6. Done!
I think he's saying that you can leave it in gear, come to a stop, turn off the car, then when you let the clutch out, keep your foot on the brake, then press the p-brake, and then let out normal brake. Then you don't have to go to neutral then back to gear.
Old Dec 4, 2002 | 09:54 PM
Lynn's Avatar
That is what I meant.
Old Dec 4, 2002 | 10:18 PM
Matt230K's Avatar
2010 C300 4matic
I can't tell whether you are confirming that that is what you meant or telling me. In any case, I don't think he got it. It should be easy enough to understand now. This is how I do it on a slope. My parking spot at my apartment is really flat. The car won't even roll on its own. So I just put it in R and leave it. Especially for the winter, I've had cars before that the p-brake froze up and that sucked.
Old Dec 4, 2002 | 10:28 PM
MarkL's Avatar
I get it now -- we just do it differently .
Old Dec 4, 2002 | 11:01 PM
Lynn's Avatar
I was agreeing with you, Matt.
