HELP.. Got my 19"s! But there is a problem!
I think there is nothing much that you can do except to get a different set of tires, or change the suspension, or change the wheels!! Pretty scrary, huh? :p Just kidding!!
Bring it to a bodyshop and see if they can do something about the panel behind the bumper (the panel that the tires are touching).
You can deal with this by either raising the car a bit or going back to 18" wheels so you can use a tire with a diameter of 25"
C class front fender is easy to roll and flare, mine is flared 10mm and the lips also rolled for a cheap price.
Try raise it up a little, or change the two front tires.
Hope your ride will be fix soon.
btw, what % tint are you using???
replace your front springs with stock and you'll have enough clearance...but sacrifice the gangsta lean
or....rip out the plastic inside the fender and watch the dealer laugh as they tell you your warranty is void
. Try to change to 225, Hope this helps
