upsolute chip claims 30hp?
just wondering just the software upgrade can make such a difference on the supercharger without pulley upgrade. I'll be very happy if it can add 20hp
MB ran these engines through every software curve possible. They already know how much further they could push it. But, as every manufacturer does, they choose a power/performance curve that best meets their final goals, reliability, and longevity.
You can take a small 1.8 liter japanese four cylinder and turbocharge it enough that it can win a World Pro Rally. But if you notice carefully, those 600HP engines don't last very long.
Just like adding NOS to a car. Sure it flies. But every single use ages/stresses the engine ever more, technically reducing its service life.
As I did my (wifes) c coupe two weeks ago and Im finishing up a cold air kit....so that I may book some dyno TIME afterwork to do a series of pulls, I did a stock pull,now I want to do a pull with the UPSOLUTE SOFTWARE done,Then a pull with the software and the cold air kit,and if the rear muffler is done well THEN I will
make a third pull with ALL THE GOODIES
as they claim 28hpand by driving it (the coupe) i believe it
FOR THE MONEYTHE UPSOLUTE IS THE BEST 325.00you can spend on your ride
as compared to the OTHERS (software companies)out there!!
cause the COUPE PULLS HARD now!!
How much was the cold air kit?
How much hp gain claimed?
Is that very time consuming/involved to pull off?
What were the numbers on the pulley kit if you know??
Thanks alot for the info on this hot topic- sounds great and cost effective!
My tip of the year- buy Nokian tires for the winter if you need them they rock!!
Thanks again dude- happy smokin' the doors off all those 325s!
C230/6speed/orion blue and you know this/C7/changer soon but not soon enough!
I cant wait for real dyno runs but with your many years as a automotive tech/racing guy what does your butt dyno tell you how many hp? whether its 10hp 20hp or 30hp range?
Young
The long term should NOT have any NEGATIVE RESULTS!as long as you USE 91/92 fuel other wise it will suffer,and ping as the knock sensors will retard the timing and slow you down..asI have done SEVERAL porsches and had NO PROBLEMS at all
The factory builds it slow for several reasons1 to improve it NEXT YEAR!!!MARKETING GOT TO LOVE IT!!and for gas reasons as most
people USE CHEAP GAS!!
The people at upsolute are GREAT because if you change any thing re cold air kit muffler they UPSOLUTE will REMAP/PROGRAM the software at NO CHARGE.Now when was the LAST time you bought a mod for your car and if you change somthing on the car they will retune it for NO CHARGE? and for 325.00!! shop the OTHERS AT 2000.00 and up I have heard nothing BUT great results about UPSOLUTE so I GAVE it a try and IT works!!
NOW THATS CUSTOMER SERVICE!!
Zimmer26
Only UPSOLUTE will install it and there is NO WAY TO TELL that you have altered the control unit!!
as for the cold air kit I have been playn with several filters as the stock air box IS VERY RESTRICTIVE look at how the air is pulled through at the drivers side then angled down, then pulled through the box to the mass air sensor THE kit Im working on uses the drivers air intake to a 45degree then straight thru the filter to the mass air sensor (I will post pictures) when Im at the dyno and with the numbers so if it works well thats
good and if it DOES not work well on to the next filter
as for the PULLEY we tried that ROUTE and the factory software
will bleed off BOOST at 3500 so if you JUST change the pulley without the software you will NOT gain anything!!
and NO I do NOT work for UPSOLUTE
just found a good product and would like to PASS on the INFO!!
http://www.upsolute.com/eng/index.html
look under dealers to see if there is one near you
Mark Cummings,
Did you get that done at their Chino Hills distributor or is there someone more local in Orange County? Would love to drag race you do see the difference between stock and your mods. We need someone to video tape it to create an mpeg for this board.
On the exhaust side, what are you thinking about installing? Evosport told me they have done a few custom installs that sounded great (not easy for a four), but they do not (yet) have a mail-order unit. I have always preferred the German DTM style tips swept upwards, but the Eisenman style twin round pipes looks good (very BMW looking).
Intake modifications can be tricky, especially in hot climates like Phoenix. Many owners loose power with modified setups and sometimes risk water intake if the pipe is low (where the cool air can be had).
I wish Mercedes had tweaked the shift up a little more aggressively, I find it a little lazy.
Anyway, some thoughts about your project...Z
The M.E. control unit CAN be opened without looking
like somone tampered with it
UPSOLUTE removes the oem flash chip reprograms it
and reinstalls it,btw they save the old program if you
WANT to back to stock?
Buellwinkle, I had it done in CHINO HILLS,btw SAN DIEGO
NEXT MONTH ? RANDALLs meet ?maybe we
can run them there?
Zonaman1, The EXHAUST is in the works and MAY be
sold thru EVOSPORT?
THE COLD AIR kit uses the oem air inlet at
the radiator core support,so NO water will
enter the INTAKE
Im using a DYNO to back up all increases
in software,intake and exhaust will post asap
