Squeaky rear....let's try this, second time around.
Old Jun 3, 2008 | 09:28 PM
Lyz's Avatar
Lyz
2003 C240 4matic-white
So, brought my car (2003 C240 4matic) in last Friday to get fixed. I originally heard from my work (Toyota dealership) that from the sounds, they thought it was the rear sway bar bushings. I brought it into Mercedes service, told them that's what was said. I get a call after the diagnosis, he said the rear springs need to be replaced. (The only "symptoms" were loud rubber sounding squeaks from the rear on turn and bumps) I got my car back today because the parts had to be ordered. After about 30 minutes of highway driving home, I drove on the back roads to get to my house and it started up again!!!!!! What is this?! I'm really starting to think that my springs were okay! The rear wasn't sagging or anything...
I'm not going to want to pay for anything else to get fixed if they should've fixed it right the first time!!
Thanks...input plz
Old Jun 3, 2008 | 09:42 PM
advans's Avatar
C55 ///AMG, 535xi
hmm. if it IS the springs, then you'll feel extra bump or that Lincoln Towncar feeling.
If it is the sway bar bushings, its more of a CLUNK kinda noise.
Old Jun 3, 2008 | 09:47 PM
Lyz's Avatar
Lyz
Hmmff... It's like really loud rubber squeaking. That's the only "symptom" I can really point out. Maybe it feels a bit like I'm swaying when going over bumps/turns. Is that what you call the towncar feel?! hahah. But maybe I only notice the light "sway" because there's a loud squeak along with it! The squeak is the only thing that really stands out. I guess If it really was the springs...I should notice a difference...but it's exactly the same.
Old Jun 3, 2008 | 11:51 PM
Mu9enx's Avatar
01' C32o
i myself have the same problem, a loud erratic squeaking. but i replaced my springs and stuff, so it must be the sway bushings
good luck!
Old Jun 3, 2008 | 11:57 PM
advans's Avatar
C55 ///AMG, 535xi
hey Lyz, why don't you try to take a video of it, maybe if the sound kicks in we can help!?
the lincoln towncar feel, I meant like suspension being so, soft, it feels like you're sitting in a boat! hahaha
GINO-ESC's Avatar
get under the car and spray the bushings with silicone spray. If the noise goes away, then replace the bushings.
Old Jun 4, 2008 | 05:24 AM
donmega23's Avatar
2005 C Sport
I just had the same problem with my '05... It turned out to be the bushings on the drivers side rear had gone out. I would only hear it on bigger bumps or with the car rocked a bit more than usual going around corners and things. I could also get it from pushing up and down on the trunk. It was crazy annoying and I was happy to get rid of it. I live in Finland and it cost me 180€ to fix.
Old Jun 4, 2008 | 06:24 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
squeaks are usually from the swaybar bushings like others said.
don't listen to the dealership idiots.
Old Jun 4, 2008 | 11:24 AM
TruTaing's Avatar
Moderator Alumni
w203 m112
Try spraying some silicone lubricant on the sway bar bracket bushings then driving around. If the sound doesnt go away, try spraying the sway bar bushings on the end links. This is what I did w/ my car and I found that the squeaking came from the end link bushings. I replaced both w/ oem parts and the squeaking went away.
Old Jun 4, 2008 | 01:09 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
New springs? Oh thats a new one.
I'd say run run away!
What could possibly go WRONG with a set of coiled up thick wires that could have ANYTHING to do with a squeaky rear?
Old Jun 4, 2008 | 01:33 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Where you been Lyz? You could have saved a coupla bucks by letting us have a think on it.
As Tru and others said, I would have the bushings sprayed heavily with silicon spray. My bet is that the sound goes away.
Old Jun 5, 2008 | 12:34 AM
tj40's Avatar
C320 Sports Coupe 2003
Does anyone know the Factory part numbers for the bushings? I have this on my C320 Coupe and I may as well change the bushings while I'm changing the suspension next week.
Thx.
TJ
Old Jun 5, 2008 | 02:24 AM
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
I had a similar problem and took it to the dealer to have it looked at along with some other stuff. Besides that, they diagnosed the squeaking coming from worn control arm bushings due to my altered suspension. They just used a lubricant and lubed up those control arm bushings and alleviated the problem severely NO CHARGE
Old Jun 5, 2008 | 02:28 AM
mtnman82's Avatar
'16 E350, gone: '03 c230k
CoupeCrazy - do you know what kind of lubricant they used? Or maybe have a part # from a receipt?
Old Jun 5, 2008 | 09:09 AM
No parts changed so couldnt tell you any pn's from my invoice. All my service adviser told me was that they used some kind of "high industrial lubricant", no brand names mentioned. Call a tech at a dealer and ask them what kind of lubricant they use on their cars Pretty sure they can give you answers.
Old Jun 5, 2008 | 09:36 AM
swiftbmx's Avatar
2003 C320 4matic sport
Well, my problem started a few thousand miles ago and now its just gotten worse. It pretty much squeaks from the front end over smaller bumps now. So in summation, it could be control arm bushings, sway bar bracket bushings or the sway bar end links. I'll pick up a good silicone lubricant from Home Depot today, anyone have a good link with pictures on how to do this? As soon as I figure it out which bushings, I'd like to get them changed immediately.
Old Jun 5, 2008 | 07:58 PM
Lyz's Avatar
Lyz
Alright.... they replaced the drivers supporting joint at the wheel carrier. That's what my paperwork says. And no, they didn't make me pay for it. Thank God. They took it as internal..otherwise I may have thrown a fit...
Thanks for everyone's input!! It sounds like it could've been a few other things as well.
p.s....squeaky brakes...does anyone know any quick and easy remedies for this )))) It can be really annoying sometimes.
Old Jun 5, 2008 | 09:10 PM
Does it occur constantly or does it occur in the morning? If only in the morning that is pretty normal. If it occurs most of the time, I think it could be due to warped rotor. Just my .02 cents, pretty sure others may have input.
Old Jun 7, 2008 | 02:06 PM
Lyz's Avatar
Lyz
it's the squeaky from the brake dust...so if i let my car sit while i'm working.. i'll have to "wear it off" by braking hard and then it'll stop. I've heard over and over that this is a part of MB brakes, there's tons of brake dust and squeaks sometimes..
Old Jun 7, 2008 | 03:59 PM
When it comes time to do your brakes, get some "Akebono" ceramic
brakes. Thats the brand.
They last forever, don't squeal, grip like crazy, and don't make a mess.
Between now and then, um, likely you're best bet is just to live with it.
In order to make sure the shop uses that brand brakes, you may have to provide them yourself.
Old Jun 7, 2008 | 05:45 PM
spyderpig's Avatar
'02 CL203 M111
Oh yeah, mb brakes squeak like crazy at half life.
Do these akebonos work with stock rotors? If so I'll change them now even if I still have half of the thread.
Old Dec 15, 2009 | 03:22 AM
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
Bumping up old thread!
I've been hearing this squeaking noise from my right rear suspension recently and it kind of comes and goes noise. Everyone suggested to spray some silicone lubricant on the sway bar bushings and endlink bushings and I think I'm going to try that. Should I be concerned about other things? I do have Tein Basic COs in my car.
The thing is I'm not familir with these bushings, can anyone please post some pictures of them? I did find some threads with decent pics and perhaps, someone can point me the bushings.
https://mbworld.org/forums/c-class-w...vers-tein.html
https://mbworld.org/forums/c-class-w...-thread-9.html
I hope John doesn't mind I borrow his threads and his pictures.
Old Dec 15, 2009 | 03:32 AM
B189s's Avatar
http://www.canadiantire.ca/AST/brows...one%2BLube.jsp
http://www.canadiantire.ca/AST/brows...mbo%2BPack.jsp
Either one should be good? Just spray and drive? How much should I spray?
Old Dec 15, 2009 | 03:51 AM
B189s's Avatar
I found some threads regarding rear squeaking. I just realized that the squeaking only happened in colder weather as it also started to squeak last winter.
https://mbworld.org/forums/c-class-w...e-diagram.html ( Post 9)
Old Dec 15, 2009 | 02:00 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
From Glyn's post on my thread:
Originally Posted by Glyn M Ruck
The sway bar bushings are #20. There are two that attach the sway bar to the body on bracket #30. While the end links are item #70, and they tend to wear out on their lower side that attaches to the the end of the sway bar.
Hope that makes some sense.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
