Quick Fix: Transmission Gasket Leaking...
Old Jun 11, 2008 | 08:56 PM
/|\/|\M-B's Avatar
2001 M-B C240
Its not leaking much but i do notice a drop or two every week so i was thinking to patch it up by throwing in one of those stop-leak bottles...my question is what brand should i use and where is the transmission fluid reservoir so i can dump one in? THX
Old Jun 11, 2008 | 09:39 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
A drop or 2 every week?
I wouldn't worry about it.
Don't pour some crap in your tranny.
You will live to regret it .
Old Jun 12, 2008 | 02:46 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
I read his post and literally gasped! DON'T PUT CRAP IN YOUR TRANNY!!!
Get under the car, take off the pans, and tighten the torx screws a bit.
If that doesn't work, you'll need to drop the pan, pull the fluid, and replace the gasket. While you are down there, change the tranny filter and fluid too.
Easy job.
E
Old Jun 12, 2008 | 09:01 PM
/|\/|\M-B's Avatar
2001 M-B C240
Thanks for the info... since both of you agree not to throw a bottle in i wont & instead ill go ahead and tighten/ replace gasket & filter
Old Jun 13, 2008 | 01:20 PM
You should check to make sure it's not leaking through the point where any wiring harnesses connect.
If you do the filter and gasket you'll need some MB tranny fluid.
Please do a search, lots of posts on that.
