In an effort to teach thy self...
Old Dec 16, 2002 | 02:27 PM
  #51
hrh's Avatar
hrh
C230K
Originally posted by Matt230K
This is true. I think I could do it very easily if I could just reach the gas a little easier with the right side of my foot. It's still okay to let off the brake to hit the gas in normal driving, and then get back on the brake. But if I ever took the car to the track someday, it wouldn't work to lift off the brake just to blip the throttle. I think a pedal modification would help.
True, briefly getting off the brakes works in most situations. True also, a slight pedal mod would help. 1/2" more pedal on the right side of the brake would be a huge help.
If you ever get the opportunity to drive a real race car, the opposite problem exists. Many formula cars, like the formula fords (now dodges) they used to use at Skip Barber had an "ear" at the right-hand side top of the brake pedal which virtually bridged the entire gap to the gas pedal. Stepping on the brake and gas came naturally. In fact, w/ size 12s, if you wanted to really stand on the brakes hard, but without hitting the gas, you had to roll the inside of your foot inward, and bring your knees together. Took some getting used to
Old Dec 16, 2002 | 04:01 PM
  #52
JustinTRW's Avatar
C32 AMG
Hrh, those are some nice pedals!
I'm a size 11, but my feet are narrow, so I actually must "heel-toe". My friend however, who is only a size 10, has feet wide enough where he uses the left part of his foot for the brake and the right side for the throttle in the same car.
Alas, in ten years or so when all gearboxes are sequential, we won't get to do this anymore.
Old Dec 16, 2002 | 05:15 PM
  #53
MarkL's Avatar
2002 C240 6-spd (ret)
Question for you guys -- how does the fact that applying the brake cuts the throttle on our throttle-by-wire cars affect heel and toe operation?
Old Dec 16, 2002 | 05:20 PM
  #54
JustinTRW's Avatar
C32 AMG
Really? I thought that was a trait of the automatic only.
Old Dec 16, 2002 | 07:05 PM
  #55
Matt230K's Avatar
2010 C300 4matic
That's a good question. It's not only on automatics. Since I have to lift the brake to reach the gas, I haven't had a chance to test it. It would be interesting for someone with wide enough feet to test.
Old Dec 16, 2002 | 08:00 PM
  #56
JustinTRW's Avatar
C32 AMG
It would be dangerous to try in anything but an empty lot but maybe you could stick it in neutral and then left foot brake to try this.
Old Dec 16, 2002 | 08:31 PM
  #57
Matt230K's Avatar
2010 C300 4matic
Well, I already know that it cuts throttle on the manual. I have tested with left foot braking before. I just haven't tested to see if the throttle will still blip if you are on the brake. And I am not sure if it does it in neutral.
Old Dec 16, 2002 | 09:49 PM
  #58
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Originally posted by MacPhisto
Yeah, my bad. People also call it "powershifting" and some other things that I can't repeat here.
My friends has a 2002 Stage 2 Roush Mustang and when ever he races he never uses the clutch, he says its fine for the car if your know what your doing. I know he is very very stupid so i would not belive a word he is saying.
Where can you rent a car with a manual tranny?
No car rental in my area rents cars with manuals, i tried. At least all the big companies like Budget, Enterprise, Avis, National, and alot of others.
Old Dec 16, 2002 | 10:45 PM
  #59
Lynn's Avatar
Okay, I just tried to rev the engine with my foot on the brake. I had the car in gear, clutch depressed, and pressed the brake with the ball of my foot and the throttle with my heel. Note, I can't do that when the car is moving. I could co it now because I didn't have to sit a the driving postion. Anyway, the rev limiter kicks in at exactly 4000 rpm.
Old Dec 16, 2002 | 10:50 PM
  #60
Matt230K's Avatar
2010 C300 4matic
Yeah, that is the rev limiter for when the car is not moving. I guess on manual it is either in neutral or with clutch in. On automatic, it is in P or N.
I also know that the throttle cutting out does not always happen. There are times when it does and times when it doesn't. I haven't figured out how you have to do it to avoid it all the time. Try driving the car slowly and then start holding the brake and see if it cuts the throttle.
Old Dec 17, 2002 | 08:18 AM
  #61
hrh's Avatar
hrh
C230K
Actually, depending on the car, your friend is right. In my Jetta (and every VW I ever owned), after the car was broken in, I rarely if ever used the clutch for anything above the 1-2 shift. When the transmission was taken apart after 70K miles of this to install a Quaife differential, the guy who put it in for me said the tranny was in great shape, and no evidence of undue wear. When the car's broken in, the shifter, with only light prodding, will move effortlessly through the gears if you keep the revs up where they belong.
The MBs transmission is very tight, at least while new, so I'm hesitant to try it until the tranny loosens up.
After our discussion yesterday, I tried playing with different techniques on the drive home. If I use the middle (arch) of my foot on the brake and my toe on the gas, it works well.
Old Dec 18, 2002 | 01:52 PM
  #62
trench's Avatar
2002 C230 K
I agree. I used to own a Chevy with a Getrag tranny - I could upshift and downshift without the clutch at will (with very smooth operation). My next car was a Honda - it's transmission never liked clutchless shifting - so I've now lost that particular "skill" .
Cheers, BT
Old Dec 18, 2002 | 02:17 PM
  #63
avlis's Avatar
2008 VW GTI
I've tried shifting without the clutch and it's a no-go. I can get it into neutral very easily by unloading the dogs (I do this on almost every upshift). It just won't go into the next gear, even if I rev the engine with the clutch out.
Old Dec 18, 2002 | 02:21 PM
  #64
CitronC230K_03's Avatar
2003 Citron Green C230KMT
definately the cluth is the key to a manual and like everyone else has pretty much said i dont think a touchshift will help very much. you need to get in a manual trans car and practice. for me when i was learning when i was 15 it was making the car go from a complete stop that was hard. but you get used to it and its all second nature in the end. you get in, and go, and shift without even thinking about it.
Old Dec 18, 2002 | 03:23 PM
  #65
Vince's Avatar
C230K
as far as heal-toeing in the coupe is concerned, it can be done. I do it left ball of my foot on the brake and then just pivot your heal to blip the gas. It took me a lot of practice to get it down. In general, heal-toeing is pretty difficult to learn. You have to understand the reasoning behind it to take full advantage of the technique. As far as blipping goes, my car has no problem with it when the clutch is pressed in. It only cuts the gas if you don't have the clutch in.
Old Dec 18, 2002 | 09:57 PM
  #66
Fast Cars!
no one answered my question yet, Where can you rent a car with a manual tranny? besides renting a ferrari at an exotic car rental.
Old Dec 18, 2002 | 10:47 PM
  #67
pocholin's Avatar
Volvo V90 CC
Re: In an effort to teach thy self...
Originally posted by 02Impressor
.. I plan on learning to drive stick. When my lease expires for the c230, I hope to buy a car with manual drive. I figure the best way to learn, is to teach myself, and what better way to start then with Tiptronic (+/-) on the c230. I know it's two very different things but the concept is the same. Shift up when it reaches X rpm and shift down when it falls to X rpm. Is there anything significant I should know when learning to drive with the shifter? I am doing this on a wide field so I will have plenty of room to speed up.
So far driving on the street , I have problems shifting down. I usually shift down to early and it makes it very akward.
Best way to learn how to shift a manual transmission is renting a manual transmission car!, Don't practice in yours
You could probably rent one at AVIS, National, etc, and if not, take a trip to Mexico, they always have manuals available
Old Dec 18, 2002 | 11:26 PM
  #68
Lynn's Avatar
It is almost impossible to rent a manual transmission car in the US. the last one I got was a Chevette in 1981.
Old Dec 19, 2002 | 10:32 PM
  #69
Fast Cars!
thats what i thought.
