2007 C230 Auxilary Audio Input?
C230
Thanks!!
Did you see the Motorola T605 I mentioned? It looks great as well. I just dont know about the install because I do not want to cut the factory wires/harnesses. I would want an install harness of sorts for anything I get.
Check post at http://www.benzworld.org/forums/w203...ut-help-4.html
It shows how to hook up a Aux input to the back of your head unit
earroyo
earroyo
I have a 2007 C230 that I just got. I would like to use a zune or something to input music. Does this car have any wired in auxiliary inputs and if so, what type? Where are they, etc?
My car does NOT have Navigation or the premium audio. It has the standard radio with numeric buttons on the right and the volume on the left.
Thanks!
Thanks!
I have the 07 c230ss w/o the white plug. here's the diy link courtesy of TBirdsaw. You really don't need to buy the MB aux plug. You can actually just solder the 3.5mm female connector.. Hope this helps
https://mbworld.org/forums/c-class-w...e-warning.html
1 Post
07 c230 sport
Thanks!
Thanks!
Did you ever resolve this? I'm facing the same issue and I'm not sure what to do.
Thanks!
Lisa
MBworld Guru
white and whiter
basically the AUX connection pins are not used behind the unit. all you need is to ID them, modify the aux wire with new pins and slide them on.
#32
if you don't have the pre-wire in the door you can just follow instruction in this thread https://mbworld.org/forums/c-class-w...e-warning.html
Lisa
#33
Hello
I have a 2007 c230 sports ,purchased it last year,and I did find the white connector where it was supposed to be,bought the cable from ECS tuning and installed it yesterday . it works perfectly .
I even added a cheap bluetooth adapter all is working well
Thanks to this forum and the members who took their time to help out
Appreciate it
Appreciate it
#34
C280
FYI, I just pulled mine apart (cracked the kick panel slightly but its not noticeable as of now).
I found NO white plug, but there was an empty black plug. I pulled everything I saw out and took pics with my cell. Please tell me if this is ready for any type of aux input and what part number it is. As I said, my radio says theres aux there if I hold down CDC. Here they are:
#35
I took my 07 c230 apart and found this black connector with the blue cables. But I think I am going to double check the door sill panel and underneath the glove box to see if it’s buried close to the head unit. If not then I think this blue connector might be it for the 07 c230
