View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Apr 15, 2010 | 12:25 PM
  #6651
XsuperbeeX's Avatar
C320 coupe
Originally Posted by B 189 NIQ
TruTaing has the same wheels and the offset seems abit aggresive, but for sure, those tires have to go. 225 or 235/40 & 255/35...
Let's wait for more answers.
+1 front may fit but rear is a little too big
Originally Posted by simppa80
Will these fronts fit with my AMG brakes????
just use spacers if it doesnt... but should be a problem
Old Apr 15, 2010 | 07:49 PM
  #6652
jefroxx's Avatar
ML320 & C320
Thanks for the heads up. Waiting for more comments or answers...
jefroxx
Old Apr 26, 2010 | 05:25 PM
  #6653
IllusionX's Avatar
2006 C230 6spd > C300 4Matic
Im not a happy camper right now, got my wheels this afternoon, changed the front two wheels and I have rubbing on the front bumper and slight rubbing on the spring.
Called the place I got them from, theyre gonna call me back. The guy reassured me they would fit fine.
19*8.5 with 235/35/19 and 19*9.5 with 265/30/19.
Any ideas?
Old Apr 26, 2010 | 10:19 PM
  #6654
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Any ideas?
Likely,... your front wheel offset is,... OFF!
First of all,... I really don't recommend your wheel-tire set up,... unless you'll only be driving at school zone speed limit on baby-*** smooth airplane runway. If you'll be driving on pothole plagued city streets then 19" rims WILL cause suspension damage to your car. I wouldn't recommend anything larger than 18".
That said,.... you're currently running the MAX wheel-tire size combo that you can on W203-CL203 without requiring wheelwell-fender roll, bodywork, wheelwell liner work, steering limiter, etc,.. if you had the correct offset!
When you run 19x8.5 235/35R19 on the front,... with Brabus 29 Offset you `should` be fine with no rubbing. But with 28 offset like on Carlsson you WILL need a crapload of wheelwell-fender roll and bodywork,... with these huge rims and tire setup it really is a game of millimeters!
What offset do you have on the front?
Old Apr 26, 2010 | 10:35 PM
  #6655
IllusionX's Avatar
Gotcha, I think I found 17s that I like by Mandrus Millennium with tires for less than what I paid. I'm just pissed because I told the dude my setup and they assured me they would work, so now I'm going to have to ship them back and it's a pain in the ***.
Old Apr 26, 2010 | 11:10 PM
  #6656
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
what suspension are you on?
what are the wheel offsets?
what tires?
where exactly(on front bumper) is it rubbing?
Old Apr 27, 2010 | 03:09 AM
  #6657
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
8.5 ET28 doesn't need fender rolling up front IF you don't have the car lowered on coilovers with no finger gap.
I'm on ET27 8.5 and 9.5 BBS LM btw.
Old Apr 27, 2010 | 03:26 PM
  #6658
IllusionX's Avatar
what tires?
Wheel offsets are 30mm, N3000s. 235/35r19 front, 265/30r19.
Stock suspension, its rubbing on the inside bumper cover, and also hitting the strut.
Old Apr 27, 2010 | 11:14 PM
  #6659
Ok,... so let's summarize,.... for 19x8.5 front wheels with 235/35R19 tires:
FrankW's 27 ET (BBS) have NO rubbing
28 ET on Carlsson will cause rubbing
29 ET on Brabus have NO rubbing
http://www.alloywheelsdirect.net/inf.../mercedes-benz
30 ET on ??? causes rubbing
Huh,... why do we look at offset (ET)???? Oh, now I get it,... odd number offsets will NOT cause rubbing,... while even number offsets WILL cause rubbing.
Old Apr 27, 2010 | 11:40 PM
  #6660
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I had no rubbing on the front on my Carlsson 1/16 BE ET28 with 235/35/19 Eagle F1 GS-D3s. The rear was 19x10 ET35 on 265.
Old May 4, 2010 | 10:30 AM
  #6661
omg its nate's Avatar
06 C230 6 Speed FTW
Would I need spaces for these? They are off a c320.
19"
5x112
Standard Offset for a c320 +35
Staggered 8.5 and 9.5
Edit
Did not fit the front needed spaces and would not look right, not sure if it would of rubbed then.
Old May 14, 2010 | 02:27 PM
  #6662
AOKTKO's Avatar
2005 c230 Sport Coupe Evo
Hello everyone, this is my first post EVER so please dont be too harsh on me.... So I'm looking at upgrading my rims on my 05 cl203 evo pkg. The problem I'm having deals with size, offset, and width. My goal is to acheive the hellaflush look minus the negative camber. I don't care about blah blah this or blah blah that as I've seen people bashed on this thread before so please save it. So back to basics, going with the pss9 c/o kit from bilstein and trying to find the right offset I would need to use to get that look. I was thinking about these rims
going with 9 inches all around instead of staggered but again the offset on those is +38 and my stocks come with a +37. So again I will mention to you all this is my first EVER posting anywhere. Please be nice...
Thanks in advance
Old May 14, 2010 | 08:45 PM
  #6663
Tump43's Avatar
2014 E350 4Matic
That's a nice looking wheel. W/ the PSS9 system 1mm difference in offset shouldn't make a difference. But, I think I read somewhere that you will need spacers to fit the PSS9's (maybe spacers are only required for KW V2's?). If you lower your car you will want to get the MB eccentric bolt front camber kit and an adjustable rear camber arm. Search and you will find.
Old May 14, 2010 | 09:47 PM
  #6664
jethal's Avatar
2007 C280 4matic
I tried searching but didn't find any info ... has anyone put AMG III or AMG III replicas on their W203? I'm thinking of putting the Sport Edition knockoff version on my 4matic, but was wondering if anyone has any pics of them fitted on their car ...
Old May 18, 2010 | 08:55 PM
  #6665
AOKTKO's Avatar
Thanks for the quick response unlike mine. So I've looked around for the MB eccentric bolt front camber kit and an adjustable rear camber arm, found it, but unfortunately can't seem to find a seller. I you know as to where I could possibly find one that would be greatly appreciated. I think I found that MB art makes the front camber kit but again no luck with a seller.
Old May 31, 2010 | 08:21 PM
  #6666
CHiKompressor's Avatar
2005 c230 S.S.
what kind of spacers would one need for the miro MO2 wheels?? F 19X8.5 et45 R 19x9.5 et48. I think the rear wouldnt fit but wanted some input from the wheel gurus
Old Jun 1, 2010 | 03:49 AM
  #6667
XsuperbeeX's Avatar
C320 coupe
o.O which car did this wheel came from?? or are you buying new?? feel like the et way too high...
Old Jun 1, 2010 | 02:18 PM
  #6668
2005 c230 S.S.
well it said it would fit a c300 (i know different offset) just wondered if spacers would make it fit nice
Old Jun 11, 2010 | 03:18 PM
  #6669
05 MB Komp's Avatar
2010 C350 Sport
Been doing a ton of research about rims and tires and just want to clarify one last time before I make the purchase.
I am looking at a set of 19" Mandrus Millenium Rims for my 2005 C230 Sedan with the big calipers.
I found a set of rims with the following offsets-
19x8.5 32 offset Front
19x9.5 35 offset Rear
Will these clear without spacers? What is the best tire size for these rims.
They sell a rim and tire package that comes with 235/35/19 in the front and 265/30/19 in the rear. Is this the optimal size or should I ask for something different?
Am I gonna get rubbing with these? No plans to change my suspension at this point so it is at stock height.
Also, I have a black car, do you guys think the black rims would make it too dark, I thought I was all set to order them but now I think it will be too dark. Looking at the hyper silver ones now.
Old Jun 12, 2010 | 11:54 AM
  #6670
05 MB Komp's Avatar
2010 C350 Sport
anyone that can help with my above question?
Old Jun 12, 2010 | 05:20 PM
  #6671
XsuperbeeX's Avatar
C320 coupe
shouldnt be any rubbing, not sure about the rear tires... and when you say big brakes is the sport brakes or the c32 brakes then there will no problem...
Old Jun 12, 2010 | 05:36 PM
  #6672
Milkm4n's Avatar
2006 c230
will a 245/35/18 fit on a 06 w203 on stock height i know everyone says 235/35/19 are max but im hopping i can make these work without them looking funny or rubbing oh im running stock sl 22 spoke wheels
Old Jun 12, 2010 | 10:06 PM
  #6673
05 MB Komp's Avatar
2010 C350 Sport
The sport brakes is what I was talking about.
How about the rears? I have read some do and some don't. Stock height should make it ok right?
Old Jun 13, 2010 | 03:54 AM
  #6674
XsuperbeeX's Avatar
C320 coupe
I ran 245/35/18 on my mrr wheels ric...
should be ok... I am not really an expert but from the looks of it should be fine..
Old Jun 13, 2010 | 09:02 AM
  #6675
Milkm4n's Avatar
2006 c230
thanks Ed I'll try this out hopefully no rub
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
