has anyone tried to replace headlight bulbs?
Note the position it's at when you pull it out, so you can line the new one up correctly.
I'm talking about getting the unit out so that I can then pull the wedge bulb out. I took off the back cover, but I was unsure how to get the unit that holds and powers the light out of the headlight assembly.
Thanks, sorry for asking the wrong question before.
It's just pulling off the harness and a twist and a pull. It sounds like you're confusing yourself.
Make sure the "stem" on the bulb is pointing up. That's the only way it will go in.
I had a hell of a time figuring that one out too...the manual couldn't be worse at describing it. I had to take a mirror down there to see what I was doing wrong.
Putting it back on is the hard part LMFAO! u better have patience and steady hands make sure u look at what u have to do before you put the new bulbs in or it will take forever. GL!
well thats the motivation i need to buy the projector headlamps and the HID's so if im gonna take errrthing apart i might as well put the new ish in!
You could get new housings, but if that is an option you want to do, you might as well upgrade your lighting to OEM Bi-Xenon and go all the way if you can afford it. The aftermarket projectors aren't going to give you the best results. Good results, but not the best.
This has been discussed quite a bit.
What happened to the DIY? and did you end up going with HIDs?
and can I ask what might be a stoopid question? why not wear a pair of cotton work gloves to avoid skin touching the bulb?
the @$$ end of that H7 looks familiar, but how do I get to it?
