C240/320 sunroof question...
2002 C240 6-spd (ret)
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
After reading someone's post about the C230 sunroof, I've got a question for the C240/320 gang. On my C240, whether I use one-touch open or hold the switch, my roof opens about 3/4 of the way. I've assumed it doesn't open the rest of the way to control wind buffetting. Does anyone's open the rest of the way if you press the switch again? Mine doesn't, and I just want to be sure there's no problem. Apparently, the C230 sunroof opens all the way on the second push.
MarkL, mine opens all the way using one-touch. No intermediate stops or need to push the button again. (Sorry)
On a related thought, the one-touch tilt up works, as advertised, but one-touch doesn't work to close it (tilt down). I have to hold the button to close.
MB-BOB, do you mean the glass retracts completely into the roof? In my full open position, part of the glass still protrudes into the opening. BTW, the tilt down happens so quickly, I've never determined if the one-touch does it -- by the time I think about it, it's closed anyway!
Originally posted by SoCal240/6
my one touch feature opens the sunroof as far as it can possibly open.
Originally posted by BigBadDad
On mine, when it is all the way open, you can see about 2" of glass. This is from the outside. I don't think it is meant to completely disappear.
MarkL, like BigBadDad, my sunroof doesn't disappear completely... When you said it opened only 3/4 of the way, I thought that was a problem. I'd say that 90-95% of my sunroof disappears when open.
Thanks for the tip on the tilt button. I'll try pushing forward to see if that works any better in autoclosing the tilt.
