Transmission Ticking
Okay, I did a STFF and couldn't really find anything too specific on my particular issue. Here's the story. I leave for work this morning and everything is fine. I'm taking it really easy going to work trying to get the best mileage out of my car that I can. Anyways, I pull up to work in the parking lot and put my car in park, and crack my windows to let air through the car. Once I open the windows though, I hear a kinda loud ticking noise? So I step out of the car while it's still running and hear that it's coming from my car! So immediately I pop the hood to see if it's coming from there, nope. Next I lay on the ground under the car, bingo! Sounds almost like an exhaust leak or an exhaust shield vibrating causing this noise, sounds like a tractor running. So I put my foot up on the resonator (the whole exhaust system and car for that matter are stock) to maybe keep it from moving or shaking if that was the problem, nothing, still ticking. So I hop in the car, put my foot on the brake and put the transmission into Reverse, IT STOPS! Then into neutral, starts ticking again! Then into drive which makes the ticking stop. So I'm wondering, has anyone have this issue before and was it in fact the transmission making this noise? If not, does anyone have any clue as to what this may be? Any help would be appreciated. I might go to the dealership at lunch, and me and my friend are going to run outside and check it out a little more closely. Thanks for reading my huge post if you did, and if I find out what's going on, I'll let you all know.
Super Moderator
Super Moderator
It could be a lot of things - noises are hell to diagnose by remote control. One persons tick is anothers clatter. The torque converter is attached to the flywheel/crankshaft by a flex plate. If these crack or break they make a whole variety of noises. If you load the box they will generally shut up. Take a long screw driver - put one end against your ear & the other on the bell housing. See if it's coming from there. It's a start. You will have to do it by a process of elimination
Done any sprint starts against the brakes lately?
Check the belt tensioners and pullies.
Seriously. I had this problem and thats what it was.
A long screwdriver can act as a stethoscope to narrow it down.
Mine was ocilating at idle, and was visible. I replaced the tensioner & pulley, belt, and idler pulley. Went away and never came back.
It could be a lot of things - noises are hell to diagnose by remote control. One persons tick is anothers clatter. The torque converter is attached to the flywheel by a flex plate. If these crack or break they make a whole variety of noises. If you load the box they will generally shut up. Take a long screw driver - put one end against your ear & the other on the bell housing. See if it's coming from there. It's a start. You will have to do it by a process of elimination
Super Moderator
BTW Pete - do you hear any strange noises when cranking the car to start? This can also provoke flex plate noise because that's what the ring gear is attached to.
Super Moderator
Hey Bud - you find anything yet? To put a positive spin on things - it could be something really simple - we always somehow expect the worse.
Not quite yet. I had the car up on jack stands over the weekend while lying underneath the car with a huge screwdriver. I was placing it on different components (and holding it up to my ear) while a friend was in the car revving the gas. I am still baffled by this sound. I was unable to duplicate what it did for me the other day when I had it parked and it was making that horrible ticking noise. Now it seems to do it at a certain RPM range, mostly while driving. Another thought that crossed my mind was loose pieces in the cat. I've had this before with another car and it sounded similar, where part of the honeycomb was loose and rattling around in the converter.
Super Moderator
While I would not call it ticking it could well be something in the exhaust, loose baffle, loose piece of honeycomb etc. This is a ***** because they move around - come & go etc depending on where whatever is loose lodges. Try hitting the exhaust with a rubber mallet - when it is cold & listen for things rattling around inside. Usually works.
Super Moderator
Super Moderator
Super Moderator
Sorry for my cryptic messages. I'm agreeing with you that it could be a mounting. I've just got him using a screwdriver against the ear to pinpoint where the noise is coming from. If he puts a long screwdriver against his ear and touches the other end of it against the mountings he will clearly hear if that's where the noise is coming from
Finally uploaded the video from my camera phone of the noise my car was making. After it doing this for a little while now, I'm starting to believe that this may be in the exhaust. I know what I said the first time, but I'm leaning towards the exhaust, at least I hope that's what it is. Let me try to attach this file, you will need Quicktime to view it, and it's kinda crappy quality. Nope, invalid file. Let me try a different approach. Okay, I just created a Google video account. I uploaded the video there. Check it out.
http://video.google.com/videoplay?do...69271227&hl=en
For all those intimate with their screw drivers....
http://www.harborfreight.com/cpi/cta...emnumber=41966
only 5 bucks to have your very own!
Gotta love harbor freight. Great thread with a lot of OG members proving input!
I dealt with a similar problem on my mom's Rav4. Turned out to be exhaust.... yet ANOTHER repair under warranty on her POS........
I still wouldn't rule out the sound being exhaust related.....
Dude, that's awesome! I'll have to check out getting one of them. There is a harbor freight store fairly close to where I live, so maybe I will take a ride up there and get on of these things. Gotta love the cheap Chinese tools! Everyone's input has been great and it is really appreciated. IF this turns out to be the exhaust, say like loose internals of one of the cats, well I guess I'll have to replace it with a nice aftermaket one!
Super Moderator
Super Moderator
Just a question - are you sure this noise is coming from under the car & not the engine?? Under the car it can only be exhaust or transmission and those are not transmission type noises although flex plate maybe but it sounds too loud & clattery. There is a distinct metallic pulse (knock) to the sound. Does this increase in frequency as you rev up the engine - like a blown exhaust manifold gasket on 1 cylinder? Are you absolutely sure that you don't have a hole in the exhaust system somewhere?
Please report.
Good god! - on my crappy screen speakers it sounds like a shot big end or small end bearing. I'm going to rig up to better speakers & have a good listen.
Please report.
Please report.
