Turn Signal Repair
Old Nov 23, 2008 | 10:19 PM
drb930's Avatar
2005 C230 Sport Coupe
Turn Signal Repair
Ok Guys,
Also posted in Tech Forum.
Here's what i found.
The computer in the car stops the voltage to the wire as soon as it detects a open fault and does not restore power to that wire until the key has been re-cycled.
The problem with my car is that the bulb socket metal tabs do not make contact with the headlight housing when the socket is fully rotated in the headlight housing on the drivers side, pass side is OK.
Don't know why, possible plastic wearing or manufacturing tolerance issues, but i digress.
The way to fix it is to take 2 wires with very small female spade connectors on the 2 wires.
Carefully plug the 2 wires into the headlight housing with the main wiring harness that goes to the headlight housing unplugged.
On the C230 the turn signal wires are the 2 bottom wires, big brown which is ground and black with white for drivers side, or black with green for pass side.
Hook up a test light powered in series with 1 wire and ground the other,
Or use a volt, ohm meter like i did.
Rotate the turn signal socket until you have the test light lit, or have continuity with the VOM.
That's it, remove the wires and plug in the main wiring harness to the headlight housing and you will have a working turn signal.
Dave
Old Nov 24, 2008 | 12:53 AM
acr2001's Avatar
2012 C300 4Matic
Maybe I'm just stupid tonight... but ... huh? what? I have no idea what you're trying to say.
Old Nov 24, 2008 | 11:53 AM
Arn560's Avatar
Black 04 C230 Kompressor SS
I'm out of breath just reading all that!
Old Nov 24, 2008 | 12:06 PM
dbvolz's Avatar
2018 C63s
Noob trying to be helpful... Uh thanks I guess.
Old Nov 24, 2008 | 01:09 PM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by drb930
Ok Guys,
Dave
Yeah - I kinda looked at this - half understood where it was going & moved on.
Thanks Dave but next time sit back & read what you have written & place yourself in the position of the receiver. Say to youself "if I was not able to visualise what was going on would I understand this?" This is the key to successful communication.
Go well
Old Nov 24, 2008 | 03:37 PM
drb930's Avatar
Sorry guys,
Just trying to be helpful.
I'm not a writer, but i am a great wrench.
Dave
Old Nov 24, 2008 | 04:01 PM
Super Moderator
Don't worry - we have many people on this forum that don't speak English as a first language from Jakarta & Metro Manila & Ho Chi Minh City & KL & HK & Lisbon & Rio & Bangkok and so on - as long as we try & communicate & understand one another & help one another.
You know the old joke. The UK & America - two countries separated by what is supposed to be a common language.
