Noisy engine when first started. Is this normal or is something wrong?
Old Dec 27, 2008 | 05:39 PM
acr2001's Avatar
2012 C300 4Matic
When I first start the engine, it sounds alright.
Then after about 10 - 15 seconds when the idle drops down (as it normally does) I start to hear this metallic noise, sounds like the timing chain but I'm not sure. It lasts for maybe 5 - 10 minutes, and then as the engine begins to warm up it's gone. The sound increases with the RPMs if I rev the engine.
The temp outside was 40 degrees and I changed the oil only a few months ago (with the proper 0W40 mobile 1 european formula, w fleece filter). I've noticed this sound since I got the car, but now it sounds a bit louder.
Engine only has ~ 25k on it!
I'm not sure if this is the timing chain or just something on the accessory belt...
I'm going to upload a sound clip as soon as I can. Warranty only has a few months left. I have a feeling my very crappy dealer is going to just tell me its normal regardless.
Old Dec 27, 2008 | 05:55 PM
bumpnzx3's Avatar
W203 C230SS
is it a ticking noise or more of a grinding noise?
Old Dec 27, 2008 | 06:31 PM
acr2001's Avatar
2012 C300 4Matic
More of a grinding noise but I wouldnt use the word grinding. Definitely not a ticking. The best thing I can compare it to, is the sound a chain makes I don't mean a timing chain but an actual chain. I'm starting to think its something on the accessory belt. I know I could easily determine this by taking the belt off and letting it run for a minute or so, but I have a feeling getting the belt back on isn't going to be so easy.
Old Dec 27, 2008 | 08:39 PM
pogijeffrey's Avatar
05 c230 kompressor
its ur belt and tensioners. i had this replaced by the dealer under the warranty. u hear the problem more during start up. i say go to the dealers if u still waranty and just leave over night. so that the next morning they could hear exactly what ur talking about.
Old Dec 28, 2008 | 11:33 AM
Glyn M Ruck's Avatar
Super Moderator
If it was the timing chain - and it's common on the 4 cyl engines - not 6. The chain would rattle at initial start up even on high idle & become quiet as soon as the oil pressure came up.(hydraulic tensioners) It certainly would not last 5 to 10 minutes unless something was very wrong. Belt tensioner is likely - presume you are not running the aircon for demisting?
Old Dec 28, 2008 | 10:45 PM
acr2001's Avatar
2012 C300 4Matic
I tried turning the A/C on and off to see if it made a difference, it does not. I didn't expect it to though since our A/C units do not use any type of clutch.
I also noticed today that when you turn the engine off, the sound continues right up until the belt stops turning (so that's probably around half a second after turning the key off). I'm going to bring it to the dealer before my warranty runs out. I have a feeling they're going to try to brush it off as a normal noise though because it isn't loud, it's about the same volume as the normal engine sound.
Old Dec 29, 2008 | 03:39 AM
Super Moderator
Yep! our aircons have no clutch but when you load them they can make a noise but this is not so here.
Tensioner pulley! - mine makes a high frequency whine but it's been consistent for 47,000 Kms so I don't care.
Old Dec 29, 2008 | 05:45 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Check that your rear catalytic convertors aren't rattling, it's a fairly common problem that can come and go depending on temperature. Timing chain problems on your engine are ALMOST non-existant. The belt tensioner can be noisy at idle and low revs but rarely when revving.
Old Dec 29, 2008 | 02:08 PM
Super Moderator
+1
