clk 430 questions
clk 430
clk 430 questions
ok so i just bought my first MB about a month ago, so the other day i came to a stop and the car started shaking so i tapped the gas and it went away, i was reading some threads and people say its the harmonic balancer? how much does that cost to fix? also it says i got a headlamp defection but all my lights work how do i make that go away?
C3Twon AWD Jumpofffff
how many miles do you have? how come you didnt post in the CLK forum?
if it just happens at a red light or idling i would check spark plugs n engine mounts first
regarding the lights are they stock or aftermarket HID?
SL55, C63
sounds like either a Crank Shaft Positioning Sensor issue, O2 sensor issue, or Mass Air Flow sensor issue.
Your engine not have the harmonic balancer! only in the M112 (V6 90°). the m113 (V8 90°) never have them..
About your lights check the rear plate lamps
