Sunroof - Express Close Issue
Old 01-02-2009, 11:12 PM
JonnyD's Avatar
'06 C230
When I go to "Express Close" the sunroof, it goes about 1/4 of the way, and then re-opens again. Is it sticking on something? There doesn't seem to be anything visible in the tracks way.
Please advise if you can.
Old 01-03-2009, 07:53 AM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
It's one of two problems:
1) need to re-synch your sunroof (search the W203 forum, or RTFM)
2) bad sunroof control module (in which case it needs to be replaced)
Check 1) first. If that doesn't work, then bend over and grab your ankles - it's gonna hurt . . . .
Old 01-03-2009, 11:36 AM
frox11's Avatar
MB 2004 C230K 6-Sp-Manual Sedan Mars Red
try lubricate the track
mine did the same thing once
Old 01-03-2009, 12:01 PM
jogger's Avatar
07 c230SS
i had the same issue and lubricated the rails and works fine now.
Old 01-03-2009, 12:18 PM
JonnyD's Avatar
'06 C230
Lubricate with?
Old 01-03-2009, 12:40 PM
XsuperbeeX's Avatar
C320 coupe
Mine had a kinda diff prob... didnt wan to close at all... just leave it a coupe of days and i work again... haha
Old 01-04-2009, 12:56 PM
frox11's Avatar
Originally Posted by JonnyD
Lubricate with?
I think the benz dealership uses grease(they used it the 1st time I complained about it). Dunno what the part number is. Nowadays I just use my bicycle chain lube, the type that is safe for metal, plastics, etc. I like the bike chain lube better because it is a dry lube, does not collect dirt.
Old 01-04-2009, 02:35 PM
pmb600's Avatar
E550 4MATIC
If your car is under warranty just bring it in. They fixed it for me when mine was doing the same issue, I think it just need to be cleaned and lubricated.
Old 01-04-2009, 07:35 PM
holycaoAMG's Avatar
A Car
+1
its definately gonna be your ONLY solutions for this. had the same problem and got solutions for the same things mentioned.
Old 01-04-2009, 08:49 PM
JonnyD's Avatar
'06 C230
It's under warranty....I'm gonna take it in.
I lubed it with WD-40 and it worked for two passes and now it's sticking again. It gets right to about 3 inches from closing, and then it stops and re-opens.
Old 01-05-2009, 12:43 PM
billbugger's Avatar
C230 Kompressor Sport Sedan
Mine does this as well. You can hold the button and it will close, but the 'express close' as you called it doesn't work for me either (closes 3/4 then opens back up).
It also does the same thing when i resynced the windows (holding lock down for like 10 seconds while pointing your key to the infrared port on your driver door handle).
It just hasn't really bothered me enough yet to drive across town to the dealer.
Old 10-25-2009, 10:51 PM
WaveyKat's Avatar
Something Slow
Anyone got a Fix for the Sunroof Express Open/Close Feature? Mines Quit Working.. i cleaned, lube & sync it but still doesn't Express Open/Close? anyone have any clue? someone mention the "control module" where is this?
thanks!
Old 10-25-2009, 11:15 PM
EV0LVE's Avatar
F10
i have had this problem with my sunroof for a long time and the dealer cant fix it. what i do is just hold the close switch until it closes completely and release after so. at first i was furious, but now it's just like operating my honda, same thing.
goodluck, and let us know if you found a different solution
Old 10-25-2009, 11:23 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
The dealer should always be able to fix it, that's weird. I had the problem, but they lubed it and it works now as well. Who knows.
Old 10-25-2009, 11:24 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My car did this and no amount of lubrication or re-synch operations would fix it. The dealer ultimately adjusted something using SDS. It has worked fine since. This was October 2008.
Old 10-26-2009, 12:09 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Do NOT use WD-40,.... Arghhhh!
WD-40 has chemical cleaners in it that will weaken and destroy rubber,... like those rubber seals around your sunroof,.. that keeps the water out.
Use SILICONE lubricant spray! Saturate all moving mechanism and track on sunroof with it. Apply once or twice every year.
BTW, use Silicone lubricant spray on all your rubber seals to keep them flexible.
Old 10-26-2009, 12:44 AM
acr2001's Avatar
2012 C300 4Matic
THIS.
Also, WD-40 realistically is not a lubricant (by my standards). It's more of a cleaner. It evaporates within a few weeks as a lubricant.
Also, yes, the stop sensor (I forget the actual name) can be "re-learned" using SDS.
Old 10-26-2009, 09:07 AM
WaveyKat's Avatar
Something Slow
hmm guess i will be going to my mechanic to get the SDS hooked up thanks guys!! man i need to buy one of those SDS machine :-D
Old 10-26-2009, 12:14 PM
LILBENZ230's Avatar
Well I can't roll my eyes back far enough in my head to express myself properly on this.. but.. my car's sunroof starting the bouncing back ***** again this morning after working fine for a year following its SDS adjustment.
WTFever. I'll just hold the button.
Old 10-26-2009, 02:51 PM
AdidasC230's Avatar
Saab 900 SE
I literally got my car back today for the same issue, and they replaced some part called the sunroof "roller blind" which basically is the track the sunroof rides on, the mounts had snapped so there was excess pressure pushing on it while closing. It was like 15 bux in parts, from what I was told. I also had "sunshade shims" replaced, because the sunshade was free to fly open and closed with acceleration and braking, not that its related. But bring it in and have it fixed, If its not under warranty, let me know and ill get the part numbers off the service ticket and take pics of it.
Old 10-26-2009, 03:23 PM
WaveyKat's Avatar
Something Slow
Please Post Part Numbers thanks :-)
Old 05-18-2011, 09:12 AM
anonymousmoose's Avatar
Audi A4 Quattro 2013
No I know first hand why people I know hate sunroofs. Happening to me too. I tried the resync and no luck. I'll contact the dealer soon. Its also grinding a little bit so may need lube.
Old 05-18-2011, 09:56 AM
cmarcho's Avatar
2005 C230 Sport
Mine was doing this and I sprayed the tracks with some lube that my garage door repair man gave me. He said this lube doesn't attract dust and lasts a long time. Don't know what it's called though, it's in a can on my garage shelf now.
My sunroof closes with one touch again.
Old 05-18-2011, 11:03 AM
gatonls's Avatar
97 E320, 04 C230K, 06 R500
I was having this problem as well.........serched up RTFM like you said Bada Boom! Magic Thanks for the info.
Old 05-18-2011, 12:41 PM
Norwichdelta06's Avatar
2007 c230
had the same issue... keep in mind theres a pinch sensor up there as well. I had to clear out a tiny tiny branch and now it works completely fine!
Quick Reply: Sunroof - Express Close Issue
