ASP Pulley installed.
Old Jan 24, 2003 | 02:15 AM
  #101
speedfrk's Avatar
C230 coupe 6sp
Originally posted by nov0798
well obviouslt the key is designed in this vehicle to transmit the torque as shown in the pulley that failed. The bolt was still tight yet the pulley wasnt turning, go figure. once again the key is there to transmit torque and protect the crank. yes i must over simplify everything as this is all people understand. tomorrow we will do colors! as for the key in the post you refer to , it sounds like this key was broken at production time and possibly the pulley was slammed on there and broke the key, who knows but eventually it to would have failed due to its lost structural integrity.
go figure- Indeed.
Old Jan 24, 2003 | 02:51 AM
  #102
DCXdynodog's Avatar
2003 C230K, 6 spd, Brilliant Silver, C-5, C-7, CD changer
it might run initially but not for long, unless it was a press fit.
WTF are you talking about?
Old Jan 24, 2003 | 03:27 AM
  #103
DCXdynodog's Avatar
Here you want a **** simple test. go out to your lawn mower remove the blade and the remove the key that is between the hub and the shaft. start it up and go mow your lawn. I bet you will not get even 2-3 minutes into your lawn b4 the blade stops turning and the crank welds itself to the hub due to friction, well actually at this point it will turn because it is welded. But i guess the key has nothing to do with this because all the force if the blade is held in place by the bolt, right! We can keep this up as I will continue to provide example after example, yet no one can prove otherwise, hmmmm.
Hmmm... My lawn mower is a commercial walk behind 48" deck with 3 blades. NONE of the blades have a key, just a large bolt (no lock washers either) and I've cut my lawn for 12 years just fine thank you!
I guess the key really has nothing to do with it.
rotflmao
Old Jan 24, 2003 | 09:57 AM
  #104
Lynn's Avatar
Originally posted by dswildfire
since when? last i checked, the rule was that if it had seeds, it's a fruit. just like cucumbers.
Wow, peas, green beans, bell peppers, lettuce, okra and most other "vegetables" are really fruits, and seedless grapes are vegetables.
Bananas do not have seeds. The black specks in the banana are the immature, unfertile beginnings of seeds.
Old Jan 24, 2003 | 10:06 AM
  #105
Lynn's Avatar
...you want a **** simple test. go out to your lawn mower...
I'm a Benz owner, by God. I don't own a lawn mower, I employ someone who does.
Old Jan 24, 2003 | 10:49 AM
  #106
mdp c230k's Avatar
2002 c230k
Amen, bother!
Seeds do not a fruit make.
Old Jan 24, 2003 | 11:04 AM
  #107
levelr123g's Avatar
yea well still waiting for the EXPERTS to dispute the documents i supplied, i guess that will never happen because it is hard to dispute fact.
Old Jan 24, 2003 | 11:36 AM
  #108
Matt230K's Avatar
2010 C300 4matic
I think we're all more interested in the dispute between fruits and vegetables. We need some documents for that.
Old Jan 24, 2003 | 11:49 AM
  #109
mctwin2kman's Avatar
Ok how about in this application both the key and the bolt torqued properly are needed. When you torgue the bolt to the right amount it will press itself onto the shaft and against the key. When the bolt is not torqued properly then the pulley must not be pressed over the key enough to keep the pulley spinning with the crank shaft. Allowing some slippage if you will. No that should not really happen but it is entirely posibble considering the amount of force present on the crank shaft. Now this being two disimiliar metals of course makes it far worse. The steel pulley matted to a steel shaft will expand and contract at the same rates therefore not leaving any room around the key to shear it like happened. Now with aluminum we have to diferent rates of expansion and contraction between the metals. Allowing the aluminum to expand more rapidly and create a gap between the key and the pulley and then of course the key will shear because the is no longer a tight fit between the key, the crank, and the pulley.
Old Jan 24, 2003 | 12:16 PM
  #110
dswildfire's Avatar
2002 C230K
see? exactly.
all the more to mess with minds of children......and my own of course.
Old Jan 24, 2003 | 12:47 PM
  #111
levelr123g's Avatar
so back to the original statement, the key is needed to transmit torque from the crank to the pulley.
Old Jan 24, 2003 | 01:00 PM
  #112
dswildfire's Avatar
2002 C230K
what's this key that we're talking about?
Old Jan 24, 2003 | 01:46 PM
  #113
mdp c230k's Avatar
2002 c230k
This is not a proven fact on our engines. The fact remains that the sheared key might be the result of not enough torque on the bolt allowing the force to be placed on the alignment pin shearing it. Proper clamping torque of the bolt might hold the pulley in position all by itself. There is also the point of aluminum against steel, the soft aluminum will not have the ability to hold under the forces while a steel pulley would have no problem. The mu of Al is much less than that of steel. At any rate, some will believe and some won't.
Old Jan 24, 2003 | 02:00 PM
  #114
speedfrk's Avatar
C230 coupe 6sp
Actually, the case I referred to was a stock factory pulley. So it was steel/steel. Aluminum is a worse case for a lot of reason including the softer material, expansion rate, etc.
"some will believe and some won't"
amen to that...
I still think nov0798 needs to go out and loosen the pulley on his car to 20-30 ft-lbs, and then let us know how things are after a few thousand miles Of course he won't do that because he knows what will happen and all the pdf files from various universities won't change the outcome.
Old Jan 24, 2003 | 03:00 PM
  #115
20FHK02's Avatar
2002 C230 Coupe
This can be true for the references you cited. But we are talking about ONE engine here: the MB M111 engine. Engine types 1, 2, 3, ..., 100 are designed to require a key to carry torque, but this doesn't mean that ALL engines must be designed to be this way, becaues there are some exceptions that aren't. It is the same ideology that fruits have seeds, but not all plants that have seeds are fruits.
Didn't tedypedy's post already show a working engine with a broken key?? If you're talking about endurance limit, all engines will fail eventually.
Old Jan 24, 2003 | 07:00 PM
  #116
levelr123g's Avatar
hmm , they are worried about the extra load placed on the keyway due to increased pulley size. if the bolt does the transfer of torque then why would they be worried about keyway stress?
http://www.nevo.biz/tech.html
Old Jan 25, 2003 | 10:46 AM
  #117
mdp c230k's Avatar
2002 c230k
Easy, because the bolt was designed to handle the amount of force encountered by the stock size pulley. If you put an extra half inch on the diameter the new torque on the pulley will be greater because it is through a greater distance, simple physics.
Old Jan 25, 2003 | 11:21 AM
  #118
x15jq's Avatar
Ok after reading this huge thread I have to comment on the lawnmower part.
The reason tehre is a key is beacause say u hit a tree stump or something that jams the blade. The key is designed to shear so the engine crank doesnt simply stop. If it did u would have a destroyed lawn mower. It would bend the crank from the sudden stop.
Same principle for our cars. If somethings stops the pulley from moving, it wont lock the crank, if it did u would bend it.
Keys are just like insurance in case something happens. Its designed to shear before engine damage occurs.
Old Jan 25, 2003 | 01:48 PM
  #119
DCXdynodog's Avatar
I cut my own lawn, by God, so I can afford to own a Benz.
Even if isn't a *real* one
Old Jan 25, 2003 | 01:58 PM
  #120
DCXdynodog's Avatar
This is wrong, go back and reread Kleeman's post. He has it correct.
Aluminum may not be the best choice but a proper design does work- some racing engines use aluminum dampers (note it is still a damper and not just a hub ).
Old Jan 25, 2003 | 06:35 PM
  #121
felix k's Avatar
ASP, Kleeman, Evosport pulleys; intercooler.........
what's the best and/or cheapest combination for getting more hp on a 2001 c240???
Old Jan 25, 2003 | 06:42 PM
  #122
Buellwinkle's Avatar
As far as I know the only only reasonably priced performance mod for you car, short of an engine swap is the Evosport underdrive pulley kit. You can put on a Kleemann supercharger/intercooler but that's about $10,000 installed from what I understand. Forum member BrabusCclass has had both done so he can give you a first hand evaluation.
Old Jan 25, 2003 | 09:05 PM
  #123
tedypedy's Avatar
Cars
I still have that little peice of the key that sheared off in my room. Here's my question. since the car runs fine, I don't see any abnormalities can I just put the ASP pulley on without worrying or is it gunna cause sum problems? However, its not just the key that was demolished. A chunk of the crank came off, and there's a little groove on the stock pulley from this explosion of bs that's going on in there. How do i get the dealer to look in there and replace everything? Hard to assess the situation but I don't know why they'd put the key in there if it didnt serve a function. I have no idea how long i've been driving with no key and all of that but I've never encounterd an engine faiure or malfunction yet. I haven't driven my car for about a week, not since i found out about the key but on the way home if anything the car felt more responsive. (still have my E as a back up car) Anyways what do you guys think i should do?
Old Jan 25, 2003 | 09:25 PM
  #124
Tedypedy, you are in a tough spot. The key is fairly long, over 2" and the part that can be seen externally is fairly small. If for some reason the rest of they works it's way out you will be in big trouble. The key is also what aligned the timing sprocket. I'll PM you with some advice I can't share on the forum.
Old Jan 25, 2003 | 09:34 PM
  #125
levelr123g's Avatar
just take it to mb and tell them that you heard a loud pop or something, ask them to check it out. or tell them the car was making a noise and when you opened the hood, you saw the pulley wobbling and so you tightened it up, but you want it towed because you are afraid to drive it. or somehting. you could always try the truth, it sometimes works and you dont have to worry about getting your stories messed up.
