HIDs for coupe
Old Jan 18, 2003 | 01:04 PM
firstkill's Avatar
HIDs for coupe
I just had Philips HID kit installed on my coupe.. it looks great.
But anyone have an idea on what to use to seal up the old plastic cap in the back?
~fk
Old Jan 18, 2003 | 02:11 PM
Robert Schrader's Avatar
Re: HIDs for coupe
~fk
How much did it cost?
Old Jan 18, 2003 | 02:21 PM
Lynn's Avatar
Re: HIDs for coupe
~fk
Silicone sealant, trim adhesive, etc.
Old Jan 18, 2003 | 03:38 PM
firstkill's Avatar
I got mine for 300 installed (used ) from a friend.
I measured the hole.. its 2'' in diameter.... i guess the best bet is using silicone to seal it..but then i can get into the housing anymore...
unless i dont seal the hole around the wires.. but that small little gap might let water in??
im not sure... im just gonna go to home depot and look for some rubber plugs or something
~fk
Old Jan 18, 2003 | 04:00 PM
Lynn's Avatar
I thought you were talking about a small hole you drilled in the cap to run some wires through.
Old Jan 18, 2003 | 04:36 PM
firstkill's Avatar
Ya.. well that small hole is 2'' hehe
The HID kits have their own Bulb and socket. THe wire is small.. but the bulb socket isnt.. so u need a larger hole to get that through. Im sure a 1.5'' hole would have worked..but i just happened to have a 2'' hole saw but
~fk
Old Jan 18, 2003 | 05:31 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: HIDs for coupe
~fk
I used rubber grommets from Radio Shack.
Old Jan 18, 2003 | 06:52 PM
firstkill's Avatar
hehe i wish i were smarter and measured the hole size that i needed to run the wire through instead of cutting a alrge hole haha
ghetto seal with electrical tape for me
~fk
Old Jan 18, 2003 | 09:30 PM
GC2TONE32's Avatar
C240
Wasn't it a plug-& play set-up??
Hey Vadim....
How do you like your HID4LESS stage I kit on your car.
I just ordered a stage II kit for my other car, and was considering a stage I for my C240
Let me know...
thanks
Old Jan 19, 2003 | 12:50 AM
firstkill's Avatar
my set up was not plug and play.. but it was simple.
The Bulb and bulb socket did not fit the 2 screw twist socket of the halogen lamp. I had to make a clip so teh bulb was in place. The i just cut the wire to the halogen bulb.. and plugged that into the ballast wires.... then ur done.
I mounted my ballast with velcro on the fendor well (again ghetto)
but the velcro is strong
~fk
Old Jan 19, 2003 | 10:05 AM
young's Avatar
GLB 250 4matic
i used electric tape
